- To:
- Subject: Re: [cgal-discuss] CGAL-2.4 Building error
- Date: Fri, 22 Feb 2008 20:40:59 +0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=LvAzLB9tISdJvdb/PTVGTCFz6sZ8TskE5P0nqO4WRNjZDaGEDcka4nx/qCmp/S7eyBX1REsEq8Wxi8RyQv0ckDDh9NqfMYoAltMCSA/SGwDdSupd3AC2lwfk7h3XIdxF4PmZ+FcA71gucd3UBo4fpgFY4aQa0AHp5NHuAslZwMU=
Dear,
Thanks for reply. But basicaly I am installing for obstacle Mobility model, which recommend the CGAL-2.4. Can you help me in this regard?
Nadir Shah
On Fri, Feb 22, 2008 at 8:34 PM, Joshua A Levine <> wrote:
Nadir,
CGAL 2.4 is not meant to be compiled with g++-4.1.1. I've had some success using g++-3.3.6 to build CGAL 2.4 on ubuntu. If you want a version that builds with g++-4.1.1, try CGAL 3.3.
Josh
Nadir Shah wrote:
> Hi all,
> I am installing CGAL-2.4 on Fedora 6,Compiler GNU4.1.1. When I
> build the CGAL-2.4 it gives me following error
> ** Compiling CGAL 2.4 **
> OS: i686_Linux-2.6.18-1.2798.fc6
> COMPILER: GNU 4.1.1
> LEDA: not supported
> GMP: not supported
> CLN: not supported
> Qt: not supported
> Generating Makefiles ... done.
> Building CGAL_lib ...
> Compilation of CGAL_lib failed.
> You will be shown a log now ...
> ** Please press <ENTER> to continue. **
> When I press enter it gives output
> /root/CGAL-2.4/include/CGAL/number_utils.h: In function 'NT
> CGAL::NTS::sqrt(const NT&)':
> /root/CGAL-2.4/include/CGAL/number_utils.h:219: error: 'sqrt' is not a
> member of 'CGAL'
> /root/CGAL-2.4/include/CGAL/number_utils.h: In function 'bool
> CGAL::NTS::is_valid(const NT&)':
> /root/CGAL-2.4/include/CGAL/number_utils.h:225: error: 'is_valid' is not a
> member of 'CGAL'
> CGAL::NTS::is_finite(const NT&)':
> /root/CGAL-2.4/include/CGAL/number_utils.h:231: error: 'is_finite' is not a
> member of 'CGAL'
> CGAL::NTS::is_integral(const NT&)':
> /root/CGAL-2.4/include/CGAL/number_utils.h:237: error: 'is_integral' is not
> a member of 'CGAL'
> make: *** [Triangulation_3.o] Error 1
> make: Target `lib' not remade because of errors.
> Kindly guide/help me in this regard. I will be very thankfull.
Nadir Shah,
Lecturer,
Department of Computer Science,
COMSATS Institute of Information Technology,
Abbottabad, Pakistan.
+923325141810
- CGAL-2.4 Building error, Nadir Shah, 02/22/2008
- Re: [cgal-discuss] CGAL-2.4 Building error, Joshua A Levine, 02/22/2008
- Re: [cgal-discuss] CGAL-2.4 Building error, Nadir Shah, 02/22/2008
