- To:
- Subject: Facet_Circulator: too few facets counted..
- Date: Fri, 29 Feb 2008 12:22:47 +0100
Hi!
I suspect that I do not use the Facet_Circulator properly.
I want to know for each edge of a RegularTriang. Facet if there is at least one neighbour facet. I do it like this:
unsigned int numOfEdgesWithNeighbours = 0;
unsigned int faceCounter = 0;
unsigned int vertices[3];
vertices[0] = (f.second+1) % 4;
vertices[1] = (f.second+2) % 4;
vertices[2] = (f.second+3) % 4;
for (unsigned int i = 0; i < 3; i++) {
// faceIndex + 1 = next vertex
// faceIndex + 2 = next next vertex, forming the edge
Rt_Facet_circulator fCirc = t_->incident_facets(f.first, vertices[i % 3], vertices[(i+1) % 3]);
Rt_Facet_circulator fCircEnd = fCirc;
faceCounter = 0;
do {
if (t_->is_infinite(*fCirc))
continue;
if ((fCirc->first == f.first) && (fCirc->second == f.second)) {
continue;
// a neighbour of a cell is every cell, which is not unkown or unused or non-singular
FacetState fState = fCirc->first->info().faces[fCirc->second];
if ((fState == fsUnkown) or (fState == fsUnused)) {
fState = fCirc->first->neighbor(fCirc->second)->info().faces[fCirc->first->neighbor(fCirc->second)->index(fCirc->first)];
switch(fState) {
case fsUnkown:
case fsUnused:
case fsSingular:
continue;
break;
default:
cout << "hasThreeNeighbours: counting as face: " << fCirc->first->info().name[fCirc->second] << " state: " << fCirc->first->info().toString(fCirc->second) << endl;
faceCounter++;
} while(++fCirc!=fCircEnd);
if (faceCounter > 0) {
cout << "hasThreeNeighbours: faceCounter=" << faceCounter << endl;
numOfEdgesWithNeighbours++;
cout << "hasThreeNeighbours: end. numOfEdgesWithNeighbours = "<< numOfEdgesWithNeighbours << endl;
return (numOfEdgesWithNeighbours == 3) ? true : false;
So, I now have the problem that some faces are counted twice. E.g. if I have the edge (2,3) I get the same face as with the edge (0,2). So there must be a bug :-)
I also tried some different algo which does a simple vertex_handle compare (e.g. iterate over all Rt_Facets of the Reg.Triang unsing the finite_facet_iterator, get the 3 edges and compare the vertex handles). This works as expected. But its inefficient. So I want to use the incident_facets stuff...
Any ideas? TIA!
Thomas
- Facet_Circulator: too few facets counted.., Thomas Zangl, 02/29/2008
- Re: [cgal-discuss] Facet_Circulator: too few facets counted.., Laurent Rineau, 02/29/2008
- Re: [cgal-discuss] Facet_Circulator: too few facets counted.., Thomas Zangl, 02/29/2008
