- To:
- Subject: Re: [cgal-discuss] Facet_Circulator: too few facets counted..
- Date: Fri, 29 Feb 2008 15:50:05 +0100
Laurent Rineau schrieb:
Hi!
Thomas, your code was quite difficult to understand. You cannot assume us to even try. Nevertheless, it was challenging, and I tried.
:-) Thank you! Maybe I found something that might be of interest in the docs for "how to use correctly the circulators". I am sure this kind of information is already somewhere documented, but not (yet) in the examples. Might be a good addition.
It is possible that fCirc is not equal to f, but is equal to t_.mirror_facet (f). It depends of the orientation of the circulator around the edge.
Thats true. I was doing the wrong check. I corrected it by using your initialization method and it works now. Thanks a million!
Best regards, Thomas
- Facet_Circulator: too few facets counted.., Thomas Zangl, 02/29/2008
- Re: [cgal-discuss] Facet_Circulator: too few facets counted.., Laurent Rineau, 02/29/2008
- Re: [cgal-discuss] Facet_Circulator: too few facets counted.., Thomas Zangl, 02/29/2008
