- To:
- Subject: Re: [cgal-discuss] line and curve intersection
- Date: Fri, 29 Feb 2008 15:07:32 +0100
wrote:
Mahmood Naderan wrote:
You have to give src+tgt. And three other points. A third point defined only a unique circle. In addition, not every combination of points defines a connected arc.
Sorry I did not understand. What do you mean by src+tgt?
source+target
As Eric recalled, you need _5_ points to uniquely define a conic, moreover, the 5 points do not always lie on the same arc of the conic.
Here, with "arc" a "connected subset in the affine plane" is meant.
Also will "CGAL::do_inersect" help me? according to manual, these types:
Polygon 2 Polygon with holes 2 General polygon 2
General polygon with holes 2
are supported by that function. So does this mean conic arc is not supported? (I think it is an abvious question)
right, more generally there are no conics nor conic arcs supported in the CGAL Kernels.
As Eric said, you may find some functionality in Arr_conic_traits_2.h (a traits class for CGAL arrangements), but _not_ in the kernel.
You should be at least able to define x-monotone conic arcs.
Circular arcs (restricted case of conic arcs) are supported by the 2D Circular Kernel. A circular arc can be uniquely defined by 3 points.
Maybe, you only need Circle .. ;-) check it.
eriC
- Re: [cgal-discuss] line and curve intersection, Mahmood Naderan, 02/28/2008
- Re: [cgal-discuss] line and curve intersection, Eric Berberich, 02/28/2008
- Re: [cgal-discuss] line and curve intersection, Ophir Setter, 02/28/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] line and curve intersection, Mahmood Naderan, 02/29/2008
- Re: [cgal-discuss] line and curve intersection, Monique . Teillaud, 02/29/2008
- Re: [cgal-discuss] line and curve intersection, Eric Berberich, 02/29/2008
