cgal-discuss - Delaunay 3D and vertices normals
  • To:
  • Subject: Delaunay 3D and vertices normals
  • Date: Thu, 6 Mar 2008 17:42:00 +0100
Hi, I'm trying to solve this problem and I'm just wondering what is the best
way of doing it.
Basically, I've got a set of points describing a shape (They're basically the
points of a surface triangulation in 3D). I've computed the normal at each
point as the average normal of all the triangles incident to this point. Now
I need to compute the 3D Delaunay tethraedisation and select those edges that
form an angle with the normal that is less than a certain threshold. I'm
using a vertex iterator to visit all the vertices and then I find all the
incident cells to that vertex, then I think there should be a way of finding
the edges incident to the vertex I'm considering (I know that in this way I'm
visiting the same edge more than once, but is the only way I can think about
now). Now it comes the problem, how can I associate a vertex with its
normal?? My points are saved into a file in the form:
x y z nx ny nz
where the first three components are the coordinates of the point and the
last three are the normal components.
I guess that the best way of dealing with these would be extending the
concept of point and adding somehow the information about the normal to that
and acces this using a method like point.get_Normal(). Is this a good
approach? In this case which class should I modify?
Thanks very much for your time and help
Angelo T.
