cgal-discuss - Re: [cgal-discuss] Visual Studio C++ development Error
  • To:
  • Subject: Re: [cgal-discuss] Visual Studio C++ development Error
  • Date: Fri, 14 Mar 2008 16:47:03 +0100
  • Organization: INRIA Sophia-Antipolis
Hi,
You should install Boost.
You can download it from http://www.boost.org.
It is enough to unzip the file. Currently only some demo programs
need the compiled Boost library "program_options".
Alternatively you can use the Installer for Boost provided
by Boost Consulting: http://www.boostconsulting/download.html.
It allows you to select precompiled libraries.
Then, you should create an environment variable named BOOSTROOT pointing to the installation folder. This part is done by CGAL installer if Boost is installed before CGAL.
Regards,
Laurent Saboret
a écrit :
Hi, all
I am trying to run segment_delaunay_graph demo,
(http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/packages.html#part_IX).
My development enviroment includes: Visual studio 2005, CGAL -3.3.1 and
QT4.3.4, the OS is Windows XP Professional.
But error occurs as belows:
"fatal error C1083: Cannot open include file: 'boost/config.hpp': No such file or
directory c:\program files\cgal-3.3.1\include\cgal\config.h 38"
Any advice is higly appreciated.
Sincerely,
Xintao.
