- To: <>
- Subject: RE: [cgal-discuss] Visual Studio C++ development Error
- Date: Sun, 16 Mar 2008 16:44:48 +0800
- Importance: Normal
Dear Laurent Saboret, Many thanks for your kind help. Here I have several questions for you: 1. About the installation order: (1). Visual Studio 2005, (2). Boost_1_34_1, (3). CGAL3.3.1, (4). QT4.3.4; 2. Boost_1_34_1, just unzip it to "C:\boost_1_34_1\", and compile it with Visual Studio 2005 Command Prompt DOS; 3. CGAL3.3.1, when in installation, there are two step of choices, (see the attached files), how to choose? I still want to complie and debug the demo program source code, and I am using Windows XP Professional. Thank you again. Sincerely, Xintao. > Date: Fri, 14 Mar 2008 16:47:03 +0100 > From: > To: > Subject: Re: [cgal-discuss] Visual Studio C++ development Error > > Hi, > > You should install Boost. > > You can download it from http://www.boost.org. > It is enough to unzip the file. Currently only some demo programs > need the compiled Boost library "program_options". > Alternatively you can use the Installer for Boost provided > by Boost Consulting: http://www.boostconsulting/download.html. > It allows you to select precompiled libraries. > > Then, you should create an environment variable named BOOSTROOT pointing to the > installation folder. This part is done by CGAL installer if Boost is installed > before CGAL. > > Regards, > -- > Laurent Saboret > INRIA Sophia-Antipolis > > > a écrit : > > Hi, all > > > > I am trying to run segment_delaunay_graph demo, (http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/packages.html#part_IX). My development enviroment includes: Visual studio 2005, CGAL -3.3.1 and QT4.3.4, the OS is Windows XP Professional. > > > > But error occurs as belows: > > "fatal error C1083: Cannot open include file: 'boost/config.hpp': No such file or directory c:\program files\cgal-3.3.1\include\cgal\config.h 38" > > > > Any advice is higly appreciated. > > > > Sincerely, > > Xintao. > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss “七件武器,七种完美” 立刻体验! |
Description: image/pjpeg
- Visual Studio C++ development Error, xintaoliu, 03/14/2008
- Re: [cgal-discuss] Visual Studio C++ development Error, Laurent Saboret, 03/14/2008
- RE: [cgal-discuss] Visual Studio C++ development Error, liuxintao, 03/16/2008
