- To:
- Subject: Re: [cgal-discuss] Problems with CGAL3+QT3
- Date: Sat, 22 Mar 2008 00:24:49 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=fazjM+4NE/4OEJuP7abO+sd7IsxfOHG24wylLz9sxXDEXQT9OCh9v4rLvyVYVQ/YaFkV6h7xUKCaQqtsMCGuGs7bm9Ls4vJPaUI7EqT0DMMyhXpvR5T91yx5cUzHHIGXhkMMQEngRmV3gMdrYO0vUwV6iBZJe+QsLMYAjvkyOv0=;
Justin:
>yes, there are qt-mt3.lib
>qt-mt3.lib
>qtmain.lib
>wsock32.lib
>winmm.lib
>imm32.lib
>cgalqt-vc71-mt.lib
>in the linker->input section
>but the errors remain
Then I think you did not build the libraries via "src" folder. Right? Please
build them.
liuxintao:
>I am also using CGAL3.3.1 + QT 3.3.8 + Visual Studio 2005, and I got the
>same error! and I have libs as >belows:
>qt-mt3.lib
>qtmain.lib
>wsock32.lib
>winmm.lib
>imm32.lib
>Any ideas? Many thanks in advance!
You have not "cgalqt.lib". Also I recommend you build the "src" folder then
add "cgalqt.lib" to "project properties->linker->input"
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Friday, March 21, 2008 11:14:19 AM
qt-mt3.lib
qtmain.lib
wsock32.lib
winmm.lib
imm32.lib
cgalqt-vc71-mt.lib
On Wed, Mar 19, 2008 at 10:22 PM, Mahmood Naderan
wrote:
>I m using CGAL3.3.1 + QT 3.3.8. when i built the demo Qt_widget/
>standard_toolbar.vcproj, it comes these >errors:
Did you add "cgalqt.lib", "qtmain.lib" and "qt-mt.lib" in "project
properties->linker->input" section?
Mahmood Naderan
To:
Sent: Monday, March 17, 2008 10:23:41 PM
Subject: [cgal-discuss] Problems with CGAL3+QT3
Dear all,
standard_toolbar.vcproj, it comes these errors:
c:\Program Files\CGAL-3.3.1\include\CGAL\float.h(133): warning C4244:
'return' : conversion from 'double' to
'CGAL::Algebraic_structure_traits_base<Type,Algebra_type>::Type', possible
loss of data
with
Type=float,
Algebra_type=CGAL::Field_with_kth_root_tag
standard_toolbar error LNK2005: "public: __thiscall QString::~QString(void)"
(??1QString@@QAE@XZ)
already defined in qt-mt3.lib(qt-mt3.dll)
standard_toolbar error LNK2005: "public: virtual void __thiscall
QWidget::setGeometry(class QRect const &)"
(?setGeometry@QWidget@@UAEXABVQRect@@@Z)
standard_toolbar error LNK2005: "public: int __thiscall
QRect::width(void)const "
(?width@QRect@@QBEHXZ)
QRect::height(void)const "
(?height@QRect@@QBEHXZ)
standard_toolbar error LNK2005: "protected: virtual void __thiscall
QWidget::setWState(unsigned int)"
(?setWState@QWidget@@MAEXI@Z)
QWidget::setWFlags(unsigned int)"
(?setWFlags@QWidget@@MAEXI@Z)
standard_toolbar error LNK2005: "public: class QColor const & __thiscall
QPen::color(void)const "
(?color@QPen@@QBEABVQColor@@XZ)
standard_toolbar error LNK2005: "public: class QPen const & __thiscall
QPainter::pen(void)const "
(?pen@QPainter@@QBEABVQPen@@XZ)
standard_toolbar error LNK2005: "public: class QBrush const & __thiscall
QPainter::brush(void)const "
(?brush@QPainter@@QBEABVQBrush@@XZ)
standard_toolbar error LNK2005: "int __cdecl qstrcmp(char const *,char const
(?qstrcmp@@YAHPBD0@Z)
QMetaObject::slotOffset(void)const "
(?slotOffset@QMetaObject@@QBEHXZ)
standard_toolbar error LNK2005: "public: class QRect const & __thiscall
QWidget::geometry(void)const "
(?geometry@QWidget@@QBEABVQRect@@XZ)
standard_toolbar warning LNK4098: defaultlib 'msvcrt.lib' conflicts with use
of other libs; use /NODEFAULTLIB:library
standard_toolbar error LNK2001: unresolved external symbol "struct QUType_int
static_QUType_int" (?static_QUType_int@@3UQUType_int@@A)
standard_toolbar error LNK2001: unresolved external symbol "private: static
struct QStringData * QString::shared_null"
(?shared_null@QString@@0PAUQStringData@@A)
standard_toolbar error LNK2001: unresolved external symbol "public: static
class QColor & Qt::green"
(?green@Qt@@2AAVQColor@@A)
class QCursor & Qt::crossCursor"
(?crossCursor@Qt@@2AAVQCursor@@A)
standard_toolbar error LNK2001: unresolved external symbol "class
QApplication * qApp" (?qApp@@3PAVQApplication@@A)
standard_toolbar error LNK2001: unresolved external symbol "struct QUType_ptr
static_QUType_ptr" (?static_QUType_ptr@@3UQUType_ptr@@A)
QUType_bool static_QUType_bool" (?static_QUType_bool@@3UQUType_bool@@A)
class QColor & Qt::black"
(?black@Qt@@2AAVQColor@@A)
class QColor & Qt::white"
(?white@Qt@@2AAVQColor@@A)
QUType_Null static_QUType_Null" (?static_QUType_Null@@3UQUType_Null@@A)
standard_toolbar fatal error LNK1120: 10 unresolved externals
anyone knows how to deal with it?
Many thanks!!
Best,
Justin
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
- Re: [cgal-discuss] Problems with CGAL3+QT3, Mahmood Naderan, 03/19/2008
- Re: [cgal-discuss] Problems with CGAL3+QT3, Justin, 03/21/2008
- RE: [cgal-discuss] Problems with CGAL3+QT3, liuxintao, 03/22/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problems with CGAL3+QT3, Mahmood Naderan, 03/22/2008
- RE: [cgal-discuss] Problems with CGAL3+QT3, liuxintao, 03/25/2008
- Re: RE: [cgal-discuss] Problems with CGAL3+QT3, 罗康生, 03/26/2008
- Re: [cgal-discuss] Problems with CGAL3+QT3, Mahmood Naderan, 03/26/2008
