cgal-discuss - Re: [cgal-discuss] Problems with CGAL3+QT3
  • To:
  • Subject: Re: [cgal-discuss] Problems with CGAL3+QT3
  • Date: Tue, 25 Mar 2008 23:24:39 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=VhRoEHa56wyGOkSBhq/dmEUrmKFTz1tL4ls/1dbXgE+K14Fh0Z0JtBVSd8vRREX3vSAsolMaBBUO3vJZL9Bw9nKEuE2CIMLIRmWfNbJP4Eyvo/Zg24qeovX5q0XBbo+tbzPi64OO4zMGD1HHp2/zDFQ09tKLg0Tg27p4Rsh2Gts=;
Hi,
Goto "$(QTDIR)\lib" and see if there is 'qt-mt3.lib'? it maynot be there
because the linker says that there is no file. See if there is a file which
is similar to this. For example "qt-mt.lib". In my system I have
"qt-mtnc321.lib".
If you want, write down all file names in "$(QTDIR)\lib" here, so that I will
tell you.
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Tuesday, March 25, 2008 8:32:04 PM
Subject: RE: [cgal-discuss] Problems with CGAL3+QT3
Dear Mahmood Naderan,
I am sorry to disturb you again.
As you told me, I complied the CGAL_80.sln in the "src" folder, and
succeeded. Then I add the cgalqt-vc80-mt.lib to the project. But I got the
new Error:
" 1 fatal error LNK1181: cannot open input file 'qt-mt3.lib'
Straight_skeleton_2 "
At the same time, I can run other examples in "C:\Program
Files\CGAL-3.3.1\examples" folder without Qt in CGAL and the Qt examples in
"C:\qt-3\examples" folder smoothly.
I am confused...
Thanks and cheers.
Xintao.
> Date: Sat, 22 Mar 2008 00:24:49 -0700
> From:
> To:
> Justin:
> >yes, there are qt-mt3.lib
> >qt-mt3.lib
> >qtmain.lib
> >wsock32.lib
> >winmm.lib
> >imm32.lib
> >cgalqt-vc71-mt.lib
> >in the linker->input section
> >but the errors remain
> Then I think you did not build the libraries via "src" folder. Right?
> Please build them.
> liuxintao:
> >I am also using CGAL3.3.1 + QT 3.3.8 + Visual Studio 2005, and I got the
> >same error! and I have libs as >belows:
> >qt-mt3.lib
> >qtmain.lib
> >wsock32.lib
> >winmm.lib
> >imm32.lib
> >Any ideas? Many thanks in advance!
> You have not "cgalqt.lib". Also I recommend you build the "src"! folder
> then add "cgalqt.lib" to "project properties->linker->input"
> Mahmood Naderan
> From: Justin
> To:
> Sent: Friday, March 21, 2008 11:14:19 AM
> qt-mt3.lib
> qtmain.lib
> wsock32.lib
> winmm.lib
> imm32.lib
> cgalqt-vc71-mt.lib
> On Wed, Mar 19, 2008 at 10:22 PM, Mahmood Naderan
> wrote:
> >I m using CGAL3.3.1 + QT 3.3.8. when i built the ! demo Qt_widget/
> >standard_toolbar.vcproj, it comes these >errors: >
> Did you add "cgalqt.lib", "qtmain.lib" and "qt-mt.lib" in "project
> properties->linker->input" section?
> Mahmood Naderan
> From: Justin
> To:
> Sent: Monday, March 17, 2008 10:23:41 PM
> Subject: [cgal-discuss] Problems with CGAL3+QT3
> Dear all,
> I m using CGAL3.3.1 + QT 3.3.8. when i built the demo Qt_widget/
> standard_toolbar.vcproj, it comes these errors:
> c:\Program Files\CGAL-3.3.1\include\CGAL\float.h(133): warning C4244:
> 'return' : conversion from 'double' to
> 'CGAL::Algebraic_structure_traits_base<Type,Algebra_type>::Type', possible
> loss of data
> with
&! gt; [
> Type=float,
> Algebra_type=CGAL::Field_with_kth_root_tag
> standard_toolbar error LNK2005: "public: __thiscall
> QString::~QString(void)"
> (??1QString@@QAE@XZ)
> already defined in qt-mt3.lib(qt-mt3.dll)
> standard_toolbar error LNK2005: "public: virtual void __thiscall
> QWidget::setGeometry(class QRect const &)"
> (?setGeometry@QWidget@@UAEXABVQRect@@@Z)
> standard_toolbar error LNK2005: "public: int __thiscall
> QRect::width(void)const "
> (?width@QRect@@QBEHXZ)
> QRect::height(void)const "
> (?height@QRect@@QBEHXZ)
> standard_toolbar error LNK2005: "protected: virtual void __thiscall
> QWidget::setWState(unsigned int)"
> (?setWState@QWidget@@MAEXI@Z)
> standard_toolbar error LNK2005: "protec! ted: virtual void __thiscall
> QWidget::setWFlags(unsigned int)" (?setWF
> lags@QWidget@@MAEXI@Z)
> standard_toolbar error LNK2005: "public: class QColor const & __thiscall
> QPen::color(void)const "
> (?color@QPen@@QBEABVQColor@@XZ)
> standard_toolbar error LNK2005: "public: class QPen const & __thiscall
> QPainter::pen(void)const "
> (?pen@QPainter@@QBEABVQPen@@XZ)
> standard_toolbar error LNK2005: "public: class QBrush const & __thiscall
> QPainter::brush(void)const "
> (?brush@QPainter@@QBEABVQBrush@@XZ)
> standard_toolbar error LNK2005: "int __cdecl qstrcmp(char const *,char
> const *)"
> (?qstrcmp@@YAHPBD0@Z)
> QMetaObject::slotOffset(void)const "
> (?slotOffset@QMetaObject@@QBEHXZ)
> standard_toolbar err! or LNK2005: "public: __thiscall
> (?setWFlags@QWidget@@MAEXI@Z)
> already defined in qt-mt3.! lib(qt-mt3.dll)
> standard_toolbar error LNK2005: "public: clas s QRect const & __thiscall
> QWidget::geometry(void)const "
> (?geometry@QWidget@@QBEABVQRect@@XZ)
> const *)"
> const *)"
> const *)"
> standard_toolbar warning LNK4098: defaultlib 'msvcrt.lib' conflicts with
> use of other libs; use /NODEFAULTLIB:library
> standard_toolbar error LNK2001: unresolved external symbol "struct
> QUType_int static_QUType_int" (?static_QUType_int@@3UQUType_int@@A)
> standard_toolbar error LNK2001: unreso! lved external symbol "private:
> static struct QStringData * QString::sh ared_null"
> (?shared_null@QString@@0PAUQStringData@@A)
> standard_toolbar error LNK2001: unresolved external symbol "private: static
> struct QStringData * QString::shared_null"
> standard_toolbar error LNK2001: unresolved external symbol "public: static
> class QColor & Qt::green"
> (?green@Qt@@2AAVQColor@@A)
> class QCursor & Qt::crossCursor"
> (?crossCursor@Qt@@2AAVQCursor@@A)
> standard_toolbar error LNK2001: unresolved external symbol "class
> QApplication * qApp" (?qApp@@3PAVQApplication@@A)
> QApplication * qAp! p" (?qApp@@3PAVQApplication@@A)
> QUType_ptr static_QUType_ptr" (?static_QUType_ptr@@3UQUType_ptr@@A)
> QUType_bool static_QUType_bool" (?static_QUType_bool@@3UQUType_bool@@A)
> class QColor & Qt::black"
> (?black@Qt@@2AAVQColor@@A)
> standard_toolbar error LNK2001: unresolved external symbol "public: static!
> class QColor & Qt::white"
> (?white@Qt@@2AAVQColor@@A)
> sta ndard_toolbar error LNK2001: unresolved external symbol "struct
> QUType_Null static_QUType_Null" (?static_QUType_Null@@3UQUType_Null@@A)
> standard_toolbar fatal error LNK1120: 10 unresolved externals
> anyone knows how to deal with it?
> Many thanks!!
> Best,
> Justin
> ____________________________________________________________________________________
> Never miss a thing. Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> ____________________________________________________________________________________!
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile. Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Windows Live Writer,支持离线撰写博客内容,随时随地想写就写。 立即使用!
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
