- To:
- Subject: Re:Re: [cgal-discuss] Mesh Generation from Point Clouds
- Date: Tue, 25 Mar 2008 08:31:35 +0800 (CST)
hi,
I wanto to know if you have the programme of harmonic mapping, which is great helpful to my research.
Wenlong LI, PhD Candidate
State Key Lab of Digital Manufacturing Equipment & Technology
Huazhong University of Science & Technology
Wuhan, Hubei, P. R. China (430074)
Tel: ++86-27-87559416-2253
Fax: ++86-27-87559415
Email:
Email:
在2008-03-24,"Pierre Alliez" <> 写道:
hi Andrew, I guess you are talking about mesh reconstruction from point sets? we are working on it - but nothing before the next release. in the meantime - if you have point sets with oriented normals I recommend http://www.cs.jhu.edu/~misha/Code/PoissonRecon/ best, Pierre Andrew Corcoran a écrit : > > Hi there, > > I''m currently using the 3D alpha shape triangulation package in CGAL > to do mesh generation for point clouds. However alpha shapes don't > seem to deal with concave surfaces or large abrupt concave angle > changes in a visually pleasing manner. > > I've come across several commercial packages that seem to do this but > nothing thats freely available. I was wondering if there are any plans > to implement other meshing algorithims for point clouds rather than > just Delaunay and Alpha in CGAL or if anyone knows of another > free/open source package that has implemented slightly more robust > point cloud meshing. > > Thanks > Andrew -- Pierre Alliez INRIA Sophia Antipolis - Mediterranee http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss
中 国 最 强 网 游 --- 网 易 梦 幻 西 游 ,166 万 玩 家 同 时 在 线
- Mesh Generation from Point Clouds, Andrew Corcoran, 03/20/2008
- Re: [cgal-discuss] Mesh Generation from Point Clouds, Pierre Alliez, 03/24/2008
- RE: [cgal-discuss] Mesh Generation from Point Clouds, Santosh Tiwari, 03/26/2008
- Re:Re: [cgal-discuss] Mesh Generation from Point Clouds, hust_lwl, 03/25/2008
- Re:Re: [cgal-discuss] Mesh Generation from Point Clouds, Bo Schwarzstein, 03/25/2008
