cgal-discuss - Re:Re: [cgal-discuss] Mesh Generation from Point Clouds
  • To: "cgal-discuss"<>
  • Subject: Re:Re: [cgal-discuss] Mesh Generation from Point Clouds
  • Date: Tue, 25 Mar 2008 09:26:23 +0800
Title: Mail
If I am not wrong, from point cloud to mesh is just a progress like this, first divide whole point cloud into small node, then apply k-nearest to find some center and neighbor, then use least-square fit like method to convert each cluster to local parameterzation coordinate system, interpolated, output.
Recently I am working on a relighting sytem, I hope it can be more like a point-based renderer compared with Lightspeed from ILM and Lpcis from PIXAR. I found that CGAL recently do not supply utility to solve these problem on point, so I am working all by myself.
Thanks for the link Pierre supplied :-)
Gott sprach: Es werde Licht! Und es wurde Licht.
----- Original Message -----
To:
Sent: 2008-03-25, 09:06:27
 hi,Alliez
 I wanto to know if you have the programme of Planar Parameterization of Triangulated Surface Meshes, which is great helpful to my research.
Wenlong LI, PhD Candidate
State Key Lab of Digital Manufacturing Equipment & Technology
Huazhong University of Science & Technology
Wuhan, Hubei, P. R. China (430074)
Tel: ++86-27-87559416-2253
Fax: ++86-27-87559415
Email:
在2008-03-24,"Pierre Alliez" <> 写道:
hi Andrew,
I guess you are talking about mesh reconstruction from point sets?
we are working on it - but nothing before the next release.
in the meantime - if you have point sets with oriented normals I recommend
http://www.cs.jhu.edu/~misha/Code/PoissonRecon/
best,
Pierre
Andrew Corcoran a écrit :
> Hi there,
> I''m currently using the 3D alpha shape triangulation package in CGAL
> to do mesh generation for point clouds. However alpha shapes don't
> seem to deal with concave surfaces or large abrupt concave angle
> changes in a visually pleasing manner.
> I've come across several commercial packages that seem to do this but
> nothing thats freely available. I was wondering if there are any plans
> to implement other meshing algorithims for point clouds rather than
> just Delaunay and Alpha in CGAL or if anyone knows of another
> free/open source package that has implemented slightly more robust
> point cloud meshing.
> Thanks
> Andrew
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
http://www-sop.inria.fr/geometrica/team/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
中 国 最 强 网 游 --- 网 易 梦 幻 西 游 ,166 万 玩 家 同 时 在 线
