- To: "" <>
- Cc:
- Subject: compiler error of Triangulation_ds_face_base_2.h
- Date: Wed, 26 Mar 2008 21:38:39 +0800
Dear All,
I use 2D triangulation algorithm of CGAL, when I compile my project with msvc2005 under release mode, there is an error, as listed following:
1>C:\Program Files\CGAL-3.3.1\include\CGAL/Triangulation_ds_face_base_2.h(88) : fatal error C1001: An internal error has occurred in the compiler.
1>(compiler file 'msc1.cpp', line 1393)
1> To work around this problem, try simplifying or changing the program near the locations listed above.
1>Please choose the Technical Support command on the Visual C++
There is no error when I compile in Debug mode. Could anyone tell me how to solve this problem? Thank you very much!
best regards
dmyan
- compiler error of Triangulation_ds_face_base_2.h, dmyan, 03/26/2008
