- To: cgal-discuss <>
- Subject: Re:Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel
- Date: Sat, 29 Mar 2008 00:03:45 +0800 (CST)
To display the error ,I uploaded an example named "Exact_or_inexact" in appendix,Click Exact_or_Inexact->Demo to run the code fragment bellow:
AfxMessageBox("Start !");
Point pa=Point(-12.1,0,1),
pd=Point(-12.1,12,1),
pe=Point(-12.1,12,4),
pf=Point(-12.1,0,4),
pk=Point(6,0,4),
pl=Point(6,12,4);
Delaunay DT;
pk=Point(6,0,4),
pl=Point(6,12,4);
Delaunay DT;
DT.insert(pa);
DT.insert(pd);
DT.insert(pe);
DT.insert(pf);
DT.insert(pk);
DT.insert(pl);
DT.insert(pd);
DT.insert(pe);
DT.insert(pf);
DT.insert(pk);
DT.insert(pl);
AfxMessageBox("Done");
I wrote the code fragment above in Exact_or_inexact class in the example project.
In my own compiler Visual Studio .net 2003,I add the following paths:
C:\Program Files\CGAL-3.2.1\include
C:\Program Files\CGAL-3.2.1\include\CGAL\config\msvc7
C:\Program Files\CGAL-3.2.1\auxiliary\gmp\include
C:\Program Files\CGAL-3.2.1\auxiliary\taucs\include
C:\Program Files\CGAL-3.2.1\auxiliary\zlib\include
and
C:\Program Files\CGAL-3.2.1\lib\msvc7
C:\Program Files\CGAL-3.2.1\auxiliary\gmp\lib
C:\Program Files\CGAL-3.2.1\auxiliary\taucs\lib
C:\Program Files\CGAL-3.2.1\auxiliary\zlib\lib
to Tools->Options->Projects->VC++ Directories->Include files and Tools->Options->Projects->VC++ Directories->Library files,respectively, and,I havn't installed Boost strictly, just downloaded boost_1_34_1.zip and unzip it,then move the unziped file into "C:\",add "C:\boost_1_34_1" to Tools->Options->Projects->VC++ Directories->Include files ,set Project->Properties->Configuration Properties->C/C++ ->Precompiled Header->Creat/Use Precompile Header to be "Not Using Precompiled Headers",
I don't know whether all these settings above has something to do with the error.
在2008-03-28,"Ophir Setter" <> 写道:
What Assertion do you get?
If I had to guess what you have to do in order to make the example work, is to construct the numbers not with double (AKA 12.1) but use a constructor that receives a numerator and denominator.
Still, I have no idea what is the problem as it should work. I also don't understand why is it different in single document.
Ophir
2008/3/28 <>:
---------- 转发邮件信息 ----------
发件人:"sanlington <>"
发送日期:2008-03-26 19:39:42
收件人:cgal-discuss <>
主题: Exact_predicates_exact_constructions_kernel
My compiler is Visual Studio .net 2003,with CGAL-3.2.1,I build a single document project,program code is as following:/**************************************************************************/#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_3<K> Delaunay;
typedef Delaunay::Point Point;Point pa=Point(-12.1,0,1),
pk=Point(6,0,4),
pl=Point(6,12,4);
Delaunay DT;
DT.insert(pa);
DT.insert(pd);
DT.insert(pe);
DT.insert(pf);
DT.insert(pk);
DT.insert(pl);/***************************************************************/In console application,this code is ok,but in single document project,it may causes an exception,it seems like "Debug Assertion Failed".If I change the coordinates of point into this:Point pa=Point(-12,0,1),
pd=Point(-12,12,1),
pe=Point(-12,12,4),
pf=Point(-12,0,4),
pk=Point(6,0,4),
pl=Point(6,12,4);,then it has no problem,or,if I keep the coordinates not being changed,but replace "<CGAL/Exact_predicates_exact_constructions_kernel.h>" and "typedef CGAL::Exact_predicates_exact_constructions_kernel K" with "<CGAL/Exact_predicates_inexact_constructions_kernel.h>" and "typedef CGAL::Exact_predicates_inexact_constructions_kernel K" respectively,it also runs successfully both in console application and single document project.I am confused by this situation,may someone tell me something about this?thanks.
中 国 最 强 网 游 --- 网 易 梦 幻 西 游 ,166 万 玩 家 同 时 在 线
Exact_or_inexact.rar
Description: Binary data
- Exact_predicates_exact_constructions_kernel, sanlington, 03/26/2008
- <Possible follow-up(s)>
- Exact_predicates_exact_constructions_kernel, sanlington, 03/28/2008
- Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel, Ophir Setter, 03/28/2008
- Re:Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel, sanlington, 03/28/2008
