- To: cgal-discuss <>
- Subject: Exact_predicates_exact_constructions_kernel
- Date: Fri, 28 Mar 2008 08:46:48 +0800 (CST)
发件人:"sanlington <>"
发送日期:2008-03-26 19:39:42
收件人:cgal-discuss <>
主题: Exact_predicates_exact_constructions_kernel
My compiler is Visual Studio .net 2003,with CGAL-3.2.1,I build a single document project,program code is as following:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_3<K> Delaunay;
typedef Delaunay::Point Point;
Point pa=Point(-12.1,0,1),
pd=Point(-12.1,12,1),
pe=Point(-12.1,12,4),
pf=Point(-12.1,0,4),
pk=Point(6,0,4),
pl=Point(6,12,4);
Delaunay DT;
pk=Point(6,0,4),
pl=Point(6,12,4);
Delaunay DT;
DT.insert(pa);
DT.insert(pd);
DT.insert(pe);
DT.insert(pf);
DT.insert(pk);
DT.insert(pl);
In console application,this code is ok,but in single document project,it may causes an exception,it seems like "Debug Assertion Failed".
If I change the coordinates of point into this:
Point pa=Point(-12,0,1),
pd=Point(-12,12,1),
pe=Point(-12,12,4),
pf=Point(-12,0,4),
pk=Point(6,0,4),
pl=Point(6,12,4);
pd=Point(-12,12,1),
pe=Point(-12,12,4),
pf=Point(-12,0,4),
pk=Point(6,0,4),
pl=Point(6,12,4);
,then it has no problem,
or,if I keep the coordinates not being changed,but replace "<CGAL/Exact_predicates_exact_constructions_kernel.h>" and "typedef CGAL::Exact_predicates_exact_constructions_kernel K" with "<CGAL/Exact_predicates_inexact_constructions_kernel.h>" and "typedef CGAL::Exact_predicates_inexact_constructions_kernel K" respectively,it also runs successfully both in console application and single document project.
I am confused by this situation,may someone tell me something about this?
thanks.
中 国 最 强 网 游 --- 网 易 梦 幻 西 游 ,166 万 玩 家 同 时 在 线
- Exact_predicates_exact_constructions_kernel, sanlington, 03/26/2008
- <Possible follow-up(s)>
- Exact_predicates_exact_constructions_kernel, sanlington, 03/28/2008
- Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel, Ophir Setter, 03/28/2008
- Re:Re: [cgal-discuss] Exact_predicates_exact_constructions_kernel, sanlington, 03/28/2008
