cgal-discuss - Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches
  • To:
  • Subject: Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches
  • Date: Fri, 28 Mar 2008 20:28:26 +0100
Hi,
Thank you for the fast response. I have just discovered another problem with IO of Arrangement_2: Unbounded and fictitious faces are apparently not correctly reconstructed when read. The problem is illustrated on a slightly changed io.cpp from examples/Arrangement_2/io.cpp which you find attached to this mail.
Kind regards,
David Keller
wrote:
Hi David,
Thank you for all this. The first 2 patches have been already applied to the internal release and will be included in the next public release.
I was able to reproduce the problem in the 3rd item below with Exact_predicates_exact_constructions_kernel and even with arrangement (without history). We'll are looking into it.
Regarding your question, equal_2_object() should return true if and only if the graphs of the curves are the same. It's a good point, and we'll add it to the documentation.
Quoting David Keller
Hi,
I have some issues with Arrangement_with_history_2:
1. operator== in Arr_with_history_2_functions.h misses a return value
for the case of non-self-assignments. Attached is a patch
(arr_with_hist_return_value.patch) which fixes the problem for me.
2. If VERBOSE is defined there are several issues with
function-name-lookups in derived objects leading to compile-time
errors (at least for gcc 4.0 and later). Attached is a patch
(sweep_line_debug.patch) to fix this problem.
3. Inserting an overlapping but "not equal" curve in an
Arrangement_with_history_2 leads to a runtime-error (precondition
failure in Arrangement_2_functions.h at line 1579). Attached is a
reproducer (arr_with_history_overlapping_curves.cpp). What should
traits::equal_2_object() implement here: Equal graph or equal
representation? The case may actually be rare. However, I'm not
quite sure if the current implementation gives the desired
behavior. If so, it would possibly be a good choice to mention
this in the documentation.
Thanks and kind regards
David Keller
//! \file examples/Arrangement_2/ex_io.cpp
// Using the arrangement I/O operators.
#include "arr_rational_nt.h"
#include <CGAL/Cartesian.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/IO/Arr_iostream.h>
#include <fstream>
#include "point_location_utils.h"
typedef CGAL::Cartesian<Number_type>                  Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel>            Traits_2;
typedef CGAL::Arrangement_2<Traits_2>                 Arrangement_2;
int main ()
  // Construct the arrangement.
  Arrangement_2    arr;
  construct_segments_arr (arr);
  std::cout << "Writing an arrangement of size:" << std::endl
            << "   V = " << arr.number_of_vertices()
            << ",  E = " << arr.number_of_edges()
            << ",  F = " << arr.number_of_faces() << std::endl;
  // Write the arrangement to a file.
  std::ofstream    out_file ("arr_ex_io.dat");
  out_file << arr;
  out_file.close();
  // Read the arrangement from the file.
  Arrangement_2    arr2;
  std::ifstream    in_file ("arr_ex_io.dat");
  in_file >> arr2;
  in_file.close();
  std::cout << "Read an arrangement of size:" << std::endl
            << "   V = " << arr2.number_of_vertices()
            << ",  E = " << arr2.number_of_edges()
            << ",  F = " << arr2.number_of_faces() << std::endl;
  if ( arr.number_of_unbounded_faces() != arr2.number_of_unbounded_faces() )
    std::cerr << "Number of unbounded faces is not equal" << std::endl;
    return (-1);
  return (0);
