Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches
- To:
- Subject: Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches
- Date: Sat, 15 Mar 2008 19:02:40 +0200
Hi David,
Thank you for all this. The first 2 patches have been already applied to the internal release and will be included in the next public release.
I was able to reproduce the problem in the 3rd item below with Exact_predicates_exact_constructions_kernel and even with arrangement (without history). We'll are looking into it.
Regarding your question, equal_2_object() should return true if and only if the graphs of the curves are the same. It's a good point, and we'll add it to the documentation.
Quoting David Keller
Hi,
I have some issues with Arrangement_with_history_2:
1. operator== in Arr_with_history_2_functions.h misses a return value
for the case of non-self-assignments. Attached is a patch
(arr_with_hist_return_value.patch) which fixes the problem for me.
2. If VERBOSE is defined there are several issues with
function-name-lookups in derived objects leading to compile-time
errors (at least for gcc 4.0 and later). Attached is a patch
(sweep_line_debug.patch) to fix this problem.
3. Inserting an overlapping but "not equal" curve in an
Arrangement_with_history_2 leads to a runtime-error (precondition
failure in Arrangement_2_functions.h at line 1579). Attached is a
reproducer (arr_with_history_overlapping_curves.cpp). What should
traits::equal_2_object() implement here: Equal graph or equal
representation? The case may actually be rare. However, I'm not
quite sure if the current implementation gives the desired
behavior. If so, it would possibly be a good choice to mention
this in the documentation.
Thanks and kind regards
David Keller
- Arrangement_with_history_2: precondition failure and patches, David Keller, 03/14/2008
- Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches, efif, 03/15/2008
- Re: [cgal-discuss] Arrangement_with_history_2: precondition failure and patches, David Keller, 03/28/2008
