cgal-discuss - Re: [cgal-discuss] bugs in Arrangement_2 (was Arrangement_with_history_2: precondition failure and patches)
  • To:
  • Subject: Re: [cgal-discuss] bugs in Arrangement_2 (was Arrangement_with_history_2: precondition failure and patches)
  • Date: Wed, 02 Apr 2008 21:15:24 +0200
Hi,
You find a patch to fix a bug in the equality-comparison of polyline-arrangements as reported in my post on 03/14: The problem is caused by the segment-wise comparison of polylines which does not take into account that polylines with different representation may share the same graph. Maybe someone is interested to check its validity or even give a more efficient implementation.
I tried to hunt down the bugs observed in IO of Arrangement_2 reported in my last post. There are seemingly different inconsistencies in the current implementation:
1. Unbounded faces are not read correctly. See my post from 03/28 for
a reproducer.
2. CGAL/Arr_accessor.h (1037) in function clear_all() : The call
p_arr->dcel.delete_all() removes DCEL-entries in the current
arrangement. This leads to dangling pointers in Arrangement_2,
i.e. the fictitious face and the vertices (un_face, v_br, v_bl,
v_tr, v_tl). The function is called from
CGAL/IO/Arrangement_2_reader.h (107). From my understanding these
pointer members in Arrangement_2 are not set when reading an
arrangement leading to an uncontrolled behavior of the
reconstructed arrangement.
3. An empty arrangement (result of default constructor of
Arrangement_2) contains one fictitious face (actually 2 DCEL
entries), 4 fictitious vertices and 4 fictitious edges. The
CGAL/IO/Arrangement_2_writer.h writes 0 fictitious vertices, 4
fictitious edges and 2 faces. It is not possible to read an empty
arrangement with the current implementation (comment Line 22 in
examples/Arrangement_2/io.cpp for a demonstration).
Can somebody sketch a solution to these problems?
Thanks and best regards
David Keller
--- CGAL-3.3.1/include/CGAL/Arr_polyline_traits_2.h	2007-08-25 21:01:33.000000000 +0200
+++ CGAL-3.3.1.patched/include/CGAL/Arr_polyline_traits_2.h	2008-04-02 09:18:37.000000000 +0200
@@ -331,21 +331,31 @@
     bool operator()(const X_monotone_curve_2 & cv1,
                     const X_monotone_curve_2 & cv2) const
-      // The two curves must contain the same number of segments.
-      unsigned int n1 = cv1.size();
-      unsigned int n2 = cv2.size();
-      if (n1 != n2)
-        return false;
-      // Check the pairwise equality of the contained segments.
       typename Segment_traits_2::Equal_2 equal = seg_traits->equal_2_object();
-      unsigned int i;
-      for (i = 0; i < n1; ++i) {
-        if (!equal(cv1[i], cv2[i]))
-          return false;
+      typename Self::Construct_min_vertex_2 min_vertex = typename Self::Construct_min_vertex_2( seg_traits );
+      typename Self::Construct_max_vertex_2 max_vertex = typename Self::Construct_max_vertex_2( seg_traits );
+      typename Self::Compare_y_at_x_2 compare_y = typename Self::Compare_y_at_x_2( seg_traits );
+      // Check if source and target are the same
+      if ( equal( min_vertex( cv1 ), min_vertex( cv2 ) ) &&
+           equal( max_vertex( cv1 ), max_vertex( cv2 ) ) )
+        // Make long (c1) and short (c2) curve
+        const X_monotone_curve_2* c1 = &cv1;
+        const X_monotone_curve_2* c2 = &cv2;
+        if ( c1->size() < c2->size() )
+          std::swap( c1, c2 );
+        // Iterate over the points in c1 and try to find them on c2.
+        typename X_monotone_curve_2::const_iterator pit1;
+        for ( pit1 = c1->begin(); pit1 != c1->end(); ++pit1 )
+          if ( compare_y( *pit1, *c2 ) != EQUAL )
+            return false;
+        return true;
-      return true;
+      return false;
