- To:
- Subject: Re: [cgal-discuss] Problem working on very large union_of_balls mesh
- Date: Thu, 03 Apr 2008 08:41:59 +0200
Hi,
I don't know too much about the mesh simplification algorithm, so I
can't help you there. From the skin surface point of view, I would
suggest to put
Union_of_balls_3 union_of_balls(ball_set.begin(), ball_set.end(),
Traits(), true);
CGAL::mesh_union_of_balls_3(union_of_balls, p);
in a block:
Traits(), true);
This because the Union_of_balls_3 constructs a rather large
triangulation internally to be able to mesh the union of ball. The block
will make sure that the destructor of union_of_balls is called and the
memory is freed. Especially since you have many points.
Could you check as well that the polyhedron is valid (p.is_valid())
after mesh_union_of_balls_3()? Just to make sure you have a valid
polyhedron to start the simplification with.
Nico
On Wed, 2008-04-02 at 17:54 +0200,
wrote:
> I am having a problem operating on a union of balls mesh. Code compiles
> and runs without errors, but it seems when the number of vertices goes over
> about 2 million, I get a run-time error if I either a)try to output the
> mesh to an OFF or b) try to simplify the mesh using the mesh simplification
> routine. Code works fine when there is under 2 million vertices. Here are
> my constructors:
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef CGAL::Skin_surface_traits_3<K> Traits;
> typedef CGAL::Union_of_balls_3<Traits>
> Union_of_balls_3;
> typedef Union_of_balls_3::Weighted_point Weighted_point;
> typedef Weighted_point::Point Bare_point;
> typedef CGAL::Polyhedron_3<K,
> CGAL::Skin_surface_polyhedral_items_3<Union_of_balls_3> > Polyhedron;
> namespace SMS = CGAL::Surface_mesh_simplification ;
> Polyhedron p;
> after adding the balls, here is my code to create the mesh and simplify,
> just as with the related example from the manual:
> Traits(), true);
> SMS::Count_stop_predicate<Polyhedron> stop(ball_set.size());
> // This the actual call to the simplification algorithm.
> // The surface and stop conditions are mandatory arguments.
> // The index maps are needed because the vertices and edges
> // of this surface lack an "id()" field.
> int r = SMS::edge_collapse
> (p
> ,stop
> ,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,
> p))
> .edge_index_map (boost::get(CGAL::edge_external_index ,
> p))
> std::ofstream out("output.off");
> out << p;
> Is there some hard limit to the number of vertices that can be processed?
> Am I using the wrong kernel? Any help is appreciated.
> BM
- Problem working on very large union_of_balls mesh, wamatt02, 04/02/2008
- Re: [cgal-discuss] Problem working on very large union_of_balls mesh, Nico Kruithof, 04/03/2008
