- To:
- Subject: Re: [cgal-discuss] Polygon skeleton
- Date: Fri, 4 Apr 2008 14:54:30 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=Xnh44/AOl9LSbFzg3dbtpSGzpQinP+tISgRoqZota1/PfPJoeANTDyGisk3H9NXWYo866trc/VbpzVDDX2UDl/JnxClf9f4hvEsUc8NMWI9lSdXm7O3K/UUZ1oJpiUkXt2i8EJFzB7RpPIUKoxCNXmQ133fNhn/dcEzYoq6SYmY=
Can you show me a little example?
How I obtain StraightSkeletonVertex_2 object by Skeleton_Builder?
Thanks
2008/4/4, Fernando Cacciola
> wrote:
> > Hi All,
> > I am using Straight Skeleton concept to find the skeleton polygon points.
> > I call a construct_skeleton() method on istance of skeleton builder to
> > compute this(It's correct?).
> Yes.
> > My question is - how can I get the coordinates of the skeleton vertex?
> Using the 'point()' function as stated in the manual:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Straight_skeleton_2_ref/Concept_StraightSkeletonVertex_2.html#Cross_link_anchor_783
> HTH
> Fernando Cacciola
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
AM
- Polygon skeleton, mistrett, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Fernando Cacciola, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Antonino Mistretta, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Andreas Fabri, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Antonino Mistretta, 04/07/2008
