- To:
- Subject: Re: [cgal-discuss] Polygon skeleton
- Date: Fri, 04 Apr 2008 15:04:44 +0200
Hi Antonino,
Did you read the manual already. I think this is covered.
andreas
Antonino Mistretta wrote:
Can you show me a little example?
How I obtain StraightSkeletonVertex_2 object by Skeleton_Builder?
Thanks
2008/4/4, Fernando Cacciola
wrote:
Hi All,Yes.
I am using Straight Skeleton concept to find the skeleton polygon points.
I call a construct_skeleton() method on istance of skeleton builder to
compute this(It's correct?).
My question is - how can I get the coordinates of the skeleton vertex?Using the 'point()' function as stated in the manual:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Straight_skeleton_2_ref/Concept_StraightSkeletonVertex_2.html#Cross_link_anchor_783
HTH
Fernando Cacciola
GeometryFactory
- Polygon skeleton, mistrett, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Fernando Cacciola, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Antonino Mistretta, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Andreas Fabri, 04/04/2008
- Re: [cgal-discuss] Polygon skeleton, Antonino Mistretta, 04/07/2008
