- To:
- Subject: Re: [cgal-discuss] Nef_polyhedron: triangular polyhedron after union operation
- Date: Sun, 06 Apr 2008 02:51:16 +0200
Hi Mengda,
in the latest CGAL version the Nef polyhedra are getting triangulated if
you convert them to polyhedral surfaces. If you want that conversion
anyway to put the resulting polyhedron out as an off file in the end,
then there should only be one problem. Not every Nef polyhedron can be
converted to a polyhedral surface. Look into the user manual for details
on that.
Peter
On Sat, 2008-04-05 at 14:59 -0700, Mengda Wu wrote:
> Hi there,
> I have two polyhedra which are triangular, manifold, and have one
> overlap region. I am wondering whether
> I can get a polyhedron which is union of the two, also triangular and
> manifold through Nef_polyhedron union operation.
> How can I ensure the faces near the joint are triangular?
> Thanks,
> Mengda
- Nef_polyhedron: triangular polyhedron after union operation, Mengda Wu, 04/05/2008
- Re: [cgal-discuss] Nef_polyhedron: triangular polyhedron after union operation, Peter Hachenberger, 04/06/2008
- Re: [cgal-discuss] Nef_polyhedron: triangular polyhedron after union operation, Mengda Wu, 04/19/2008
