- To:
- Subject: Re: [cgal-discuss] fix border edges for mesh simplification
- Date: Sat, 05 Apr 2008 22:14:45 -0400
hi Fernando
your attached code works nicely, and now all border nodes are
preserved.
thank you so much for your help.
Qianqian
Fernando Cacciola wrote:
I'm afraid I would have to investigate this further but I can't do that now.
The only idea I can give you at this point is to wrap the GetCost function to prevent collpasing any edge adjacent to a border edge:
template<class GetCost_>
struct Cost_with_fixed_edges : GetCost_
typedef GetCost_ GetCost ;
typedef typename GetCost::Profile Profile ;
typedef typename GetCost::Point Point ;
typedef typename GetCost::result_type result_type ;
result_type operator()( Profile const& aProfile, boost::optional<Point> const& aPlacement ) const
if ( aProfile.border_edges().size() > 0 )
return boost::none ;
else
return this->GetCost::operator()(aProfile, aPlacement);
typedef Cost_with_fixed_edges< SMS::Edge_length_cost<Surface> > My_cost ;
int r = SMS::edge_collapse
(surface
,stop
,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,surface))
.edge_index_map (boost::get(CGAL::edge_external_index ,surface))
.get_cost (My_cost())
.get_placement (SMS::Midpoint_placement<Surface>())
HTH
Fernando Cacciola
GeometryFactory
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 04/01/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 04/01/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 04/03/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 04/06/2008
