cgal-discuss - Inset polygon/buffering: straights skeleton vs. arranagement
  • To:
  • Subject: Inset polygon/buffering: straights skeleton vs. arranagement
  • Date: Sat, 05 Apr 2008 23:33:55 -0400
Hi Y'all,
First, if this is a FAQ or already covered, I do apologize. I am just getting back to CGAL after several years; X-Plane's open source scenery generation code base uses CGAL for Delauney triangulation to build our irregular mesh and we have a planar map that is an offshoot of the old pmwx class. (We're looking at moving to the new arrangement_2.)
We need polygon-inset operations for GIS-type algorithms; there seem to be two candidates:
1. Build a straight skeleton and use the offset builder; our current code uses a home-rolled version of Fernando Cacciola's algorithm (and he was exceedingly helpful in understanding the problem when we were working on it :-).
2. Use an arrangement to build the buffer curves around the basic polygon and its holes. The arrangement's ability to find intersections will give us something consistent that we can then use to find the derived shapes of the buffer zone. (Essentially we deal with merging polygons by letting the arrangement figure out what happened.) This approach is similar to how GEOS does its buffers.
Before I replace our existing code with one of these technquies, does anyone have any suggestions on which way to go?
- We have a lot of input data cases where the input polygon has a really large number of sides (1000+) but the offset distance is very, very small compared to the overall size of the polygon. The inset contours will have very few "events".
In my old code, where I was only interested in a slightly inset contour and not the entire skeleton, I got a big performance win by halting the inset operation once I'd exceeded the "time" that my offset needed. Basically I could throw out and not evaluate the entire event list.
Is there a way to do this in the CGAL skeleton/offset classes? If not, am I going to hit a performance problem?
Anyway, any advise from people who are doing polygon insetting/buffering would be much appreciated!
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
Scenery mailing list:
Developer mailing list:
