- To:
- Subject: BUG in Filtered_bbox_circular_kernel_2
- Date: Thu, 10 Apr 2008 16:48:33 +0200
- Organization: IST TU Graz
When using the Filtered_bbox_circular_kernel_2 and checking the results with
valgrind, I experienced some huuuuuge memory leaks resulting from (i guess)
the bounding box assignment. I wrote some small example for this issue:
#include <CGAL/Cartesian.h>
#include <CGAL/Algebraic_kernel_for_circles_2_2.h>
#include <CGAL/Circular_kernel_2.h>
#include <CGAL/Filtered_bbox_circular_kernel_2.h>
#include <CGAL/Real_embeddable_traits.h>
#include <CGAL/Arr_circular_line_arc_traits.h>
#include <CGAL/Conic_2.h>
typedef double dbl;
typedef CGAL::Cartesian<dbl> LK;
typedef CGAL::Algebraic_kernel_for_circles_2_2<dbl> AK;
typedef CGAL::Circular_kernel_2<LK,AK> K_;
//when replaceing this filtered kernel with circular kernel, no leak happens
typedef CGAL::Filtered_bbox_circular_kernel_2<K_> K;
typedef K::Line_2 Line;
typedef K::Point_2 Pnt;
typedef K::Circular_arc_point_2 Point;
typedef K::Circle_2 Disk;
typedef K::Circular_arc_2 Circular_arc;
typedef std::back_insert_iterator<std::vector<CGAL::Object> > OutputIter;
// intersection for line and circle, just to get two points on a disk
OutputIter Intersect(const Line &l, const Disk &d, OutputIter res)
K::Polynomial_1_2 e1 = CGAL::get_equation<K>(l);
K::Polynomial_for_circles_2_2 e2 = CGAL::get_equation<K>(d);
typedef std::vector< std::pair < K::Root_for_circles_2_2, unsigned >
solutions_container;
solutions_container solutions;
K::Algebraic_kernel().solve_object()(e1, e2,
std::back_inserter(solutions));
for ( solutions_container::iterator it = solutions.begin(); it !=
solutions.end(); ++it )
*res++ = make_object(std::make_pair(Point(it->first),
it->second ));
return res;
int main(int argc, char *argv[])
Line l(Pnt(1.12,3.08), Pnt(7.61,7.49));
Disk d(Pnt(5,4.6), 11.11, CGAL::CLOCKWISE);
Disk d2(Pnt(7.61,4.6), 10.2, CGAL::CLOCKWISE);
std::vector<CGAL::Object> result_;
Intersect(l, d, std::back_inserter(result_));
std::pair<Point,unsigned> p1_, p2_;
CGAL::assign(p1_, result_[0]);
CGAL::assign(p2_, result_[1]);
result_.clear();
Circular_arc arc(d, p1_.first, p2_.first);
// here the memory leak happens when using filtered kernel
K().intersect_2_object()(d2, arc, std::back_inserter(result_));
return(1);
When valgrinding this with "valgrind --leak-check=full", I lost two blocks
with 32 bytes each "definitely".
If I replace the Filtered_bbox_circular_kernel with the normal
Circular_kernel, then the leak disappears.
I need the memory :) any suggestions?
lg, Wolfgang
- BUG in Filtered_bbox_circular_kernel_2, Wolfgang Aigner, 04/10/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Wolfgang Aigner, 04/10/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Pedro Machado Manhães de Castro, 04/11/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Wolfgang Aigner, 04/11/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Andreas Fabri, 04/17/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Wolfgang Aigner, 04/18/2008
- Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2, Andreas Fabri, 04/18/2008
