cgal-discuss - Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2
  • To:
  • Subject: Re: [cgal-discuss] BUG in Filtered_bbox_circular_kernel_2
  • Date: Fri, 18 Apr 2008 13:50:33 +0200
Wolfgang Aigner wrote:
simple destructor with delete for bbox if not NULL indeed did the job,
thank you!
I am not sure that this is enough. When you copy construct a point
the pointer is just copied. So when you destruct the first copy
the shared bbox is deleted.
andreas
True. It worked for the minimal example, but seems generally to be a bit more complicated. A solution would be a reference counter or a smart pointer i guess.
wolfgang
Or a copy constructor setting the bbox to NULL. The function
accessing the bbox creates it on the fly if necessary.
andreas
