cgal-discuss - Re: [cgal-discuss] non-regularized minkowski sum, license
  • To:
  • Subject: Re: [cgal-discuss] non-regularized minkowski sum, license
  • Date: Sun, 13 Apr 2008 01:45:00 +0300
Quoting Michael George
Greetings,
I've been struggling for some time now to extend the minkowski sum code
in CGAL to produce non-regularized output (i.e. to retain the low
dimensional features). I've explored a variety of designs to perform
the union of cycles, but it seems to me like the arrangement package is
just slightly too inflexible to accomodate each design. I have two
questions:
I guess it is a matter of opinion, but I would say that the arrangement package is a good choice to accomplish your task. Besides, what do you mean by 'each' above?
1. Has anyone managed to do this? If so, how?
Do what exactly? The Minkowski sum package supports two different methods to compute the exact Minkowski sum, one uses decomposition and union, and the other is based on convolution. The latter may already handle the low dimensional features. The former does not, because it uses the union operation, which does not, so the problem reduces to computing the non-regularized union. What type of boundary curves are we talking about?
2. If not, I'm probably going to have to implement my own sweep-line
algorithm to do the merging, instead of using the arrangement package.
At that point I would probably break away from CGAL entirely and just
implement everything from scratch for simplicity. I'm wondering if
this would still be considered a derived work for licensing purposes,
since I wouldn't have any CGAL code but would still be using the design
of CGAL and the minkowski sum algorithm in it as a guide? I'd like to
license my code under the GPL which is incompatible with the QT license.
That depends on how close to the original code your code is going to be, and whether your final code will absolutely not have any sign of the original code.
The convolution algorithm and the decomposition algorithm to compute Minkowski sums where published and appear in the literature.
Thanks,
--Mike
