- To:
- Subject: Re: [cgal-discuss] non-regularized minkowski sum, license
- Date: Sun, 13 Apr 2008 09:35:58 -0400
wrote:
Quoting Michael GeorgeBe 'each' I mean each design I've come up with to perform the union (I'm admittedly not that clever which is why I'm asking for advice). The problem I keep having is that in order to support finding the low-dimensional features (points in particular) of the boundary, one needs to traverse the original cycles in order and mark the half-edges that are on the inside of the path. I can't find any correct way to keep these information up to date as the arrangement package constructs the arrangement.
Greetings,
I've been struggling for some time now to extend the minkowski sum code
in CGAL to produce non-regularized output (i.e. to retain the low
dimensional features). I've explored a variety of designs to perform
the union of cycles, but it seems to me like the arrangement package is
just slightly too inflexible to accomodate each design. I have two
questions:
I guess it is a matter of opinion, but I would say that the arrangement package is a good choice to accomplish your task. Besides, what do you mean by 'each' above?
1. Has anyone managed to do this? If so, how?
Do what exactly? The Minkowski sum package supports two different methods to compute the exact Minkowski sum, one uses decomposition and union, and the other is based on convolution. The latter may already handle the low dimensional features. The former does not, because it uses the union operation, which does not, so the problem reduces to computing the non-regularized union. What type of boundary curves are we talking about?
The current minkowski sum (by convolution) code works by storing some data in the x monotone curve objects, and updating this on intersect and split. But in order to keep this ordering information up to date, it would have to do destructive updates, which it can't because the caller of intersect must throw out part of the output.
I've considered using the arrangements with history, but they provide no way to perform an _ordered_ traversal of the original curves. This ordering is key.
I've considered using an overlay-based solution to do incremental merging, but this doesn't solve the problem because even an individual convolution cycle can double back on itself, so putting the individual cycles into the arrangement to compute the overlay brings up the same problems above.
The best I can think of is to delve into the arrangement code and provide more flexibility for updating data structures as curves are added to the arrangement, but if I'm digging that far down in the stack I'm not sure there's still a lot of benefit to not setting off and writing special purpose code. I lose the advantage of using a well-tested, widely used library, but I'll gain simplicity and flexibility in the design.
I'd ultimately like to use this for curves that are a mix of line segments and arcs, but I'd be happy for starters to get it working with polygons. Obviously if I want to extend it to arcs, I would have to significantly modify the code that generates the convolution cycles as well.
Thanks for your help.
--Mike
- non-regularized minkowski sum, license, Michael George, 04/12/2008
- Re: [cgal-discuss] non-regularized minkowski sum, license, efif, 04/13/2008
- Re: [cgal-discuss] non-regularized minkowski sum, license, Michael George, 04/13/2008
