cgal-discuss - Re: [cgal-discuss] Need help: Bug in overlay for Arrangement_2 with overlapping subcurves
  • To:
  • Subject: Re: [cgal-discuss] Need help: Bug in overlay for Arrangement_2 with overlapping subcurves
  • Date: Thu, 17 Apr 2008 01:44:22 +0300
Hi David,
You have encountered a real bug that hasn't been reported yet. I was able to reproduce it. Thanks for the simple test case!
We'll look into it, and we'll let you know. Stay tuned...
Quoting David Keller
Hi,
sorry for insisting on similar topics here: I came across a failure
caused by overlaying two arrangements with partially overlapping curves.
You find a test scenario containing two test cases attached to this
mail. Both test cases fail by throwing an exception, actually a
precondition failure in CGAL. The program gives the following output:
====== BEGIN OUTPUT ======
Running 2 test cases...
CGAL error: assertion violation!
Expr: !pt.is_red_object_null() || !pt.is_blue_object_null()
File:
../../../../libs/external/cgal/CGAL-3.3.1/include/CGAL/Arr_overlay_2/Overlay_visitor.h
Line: 594
Explanation:
arr_overlay_with_orverlapping_curves.cpp(59): error in
"simple_overlay_test": exception thrown by CGAL::overlay( arr1, arr2,
ovl, ot )
Expr: !pt.is_blue_object_null()
File:
Line: 271
Explanation:
arr_overlay_with_orverlapping_curves.cpp(83): error in "overlay_test":
exception thrown by CGAL::overlay( arr1, arr2, ovl, ot )
*** 2 failures detected in test suite "Master Test Suite"
EXIT STATUS: 201
====== END OUTPUT ======
When trying to debug these I found Overlay_visitor being called with
event points which miss a correct point_info, i.e. their relations to
objects in the "blue" and "red" arrangement is not set.
Overlay_meta_traits actually gets the correct information on
overlapping subcurves and associates these curves with "purple"
information. However, the end points are apparently not correctly
flagged with "purple" information and thus violate the preconditions in
Overlay_visitor.
I have actually no idea how to further debug these things, at least
from my point of view the code in Overlay_visitor and
Overlay_meta_traits is not easily readable. Hence, I would be glad to
get further hints on where to look at or even on how to fix this issue.
Maybe the problem is even known and there is a fix for it?
Thanks and regards
David Keller
