cgal-discuss - Need help: Bug in overlay for Arrangement_2 with overlapping subcurves
  • To:
  • Subject: Need help: Bug in overlay for Arrangement_2 with overlapping subcurves
  • Date: Wed, 16 Apr 2008 16:09:03 +0200
Hi,
sorry for insisting on similar topics here: I came across a failure caused by overlaying two arrangements with partially overlapping curves.
You find a test scenario containing two test cases attached to this mail. Both test cases fail by throwing an exception, actually a precondition failure in CGAL. The program gives the following output:
====== BEGIN OUTPUT ======
Running 2 test cases...
CGAL error: assertion violation!
Expr: !pt.is_red_object_null() || !pt.is_blue_object_null()
File: ../../../../libs/external/cgal/CGAL-3.3.1/include/CGAL/Arr_overlay_2/Overlay_visitor.h
Line: 594
Explanation:
arr_overlay_with_orverlapping_curves.cpp(59): error in "simple_overlay_test": exception thrown by CGAL::overlay( arr1, arr2, ovl, ot )
Expr: !pt.is_blue_object_null()
Line: 271
Explanation:
arr_overlay_with_orverlapping_curves.cpp(83): error in "overlay_test": exception thrown by CGAL::overlay( arr1, arr2, ovl, ot )
*** 2 failures detected in test suite "Master Test Suite"
EXIT STATUS: 201
====== END OUTPUT ======
When trying to debug these I found Overlay_visitor being called with event points which miss a correct point_info, i.e. their relations to objects in the "blue" and "red" arrangement is not set. Overlay_meta_traits actually gets the correct information on overlapping subcurves and associates these curves with "purple" information. However, the end points are apparently not correctly flagged with "purple" information and thus violate the preconditions in Overlay_visitor.
I have actually no idea how to further debug these things, at least from my point of view the code in Overlay_visitor and Overlay_meta_traits is not easily readable. Hence, I would be glad to get further hints on where to look at or even on how to fix this issue. Maybe the problem is even known and there is a fix for it?
Thanks and regards
David Keller
// #define VERBOSE
#define BOOST_TEST_MAIN
#include <boost/test/unit_test.hpp>
#include <sstream>
#include <boost/array.hpp>
#include <CGAL/Arrangement_with_history_2.h>
#include <CGAL/Arr_polyline_traits_2.h>
#include <CGAL/Arr_non_caching_segment_traits_2.h>
#include <CGAL/Arr_extended_dcel.h>
#include <CGAL/Arr_overlay.h>
#include <CGAL/Arr_default_overlay_traits.h>
struct VertexData
struct HalfedgeData
struct FaceData
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Arr_non_caching_segment_traits_2<Kernel>      SegmentTraits;
typedef CGAL::Arr_polyline_traits_2<SegmentTraits>          Traits;
typedef CGAL::Arr_extended_dcel<Traits, VertexData, HalfedgeData, FaceData>
                                                            Dcel;
typedef CGAL::Arrangement_with_history_2<Traits,Dcel>       Arrangement;
typedef Traits::Curve_2                                     Curve;
typedef Traits::Point_2                                     Point;
typedef CGAL::Arr_default_overlay_traits<Arrangement>       Overlay_traits;
BOOST_AUTO_TEST_CASE( simple_overlay_test )
  Arrangement arr1, arr2, ovl;
  std::vector<Curve> curves;
  std::vector<Point> points;
  points.push_back( Point( 0., 0. ) );
  points.push_back( Point( 10., 0. ) );
  curves.push_back( Curve( points.begin(), points.end() ) );
  points.clear();
  points.push_back( Point( 1., -1. ) );
  points.push_back( Point( 2., 0. ) );
  points.push_back( Point( 5., 0. ) );
  points.push_back( Point( 7., 1. ) );
  points.clear();
  CGAL::insert_curves( arr1, curves.begin(), curves.begin() + 1 );
  CGAL::insert_curves( arr2, curves.begin() + 1 , curves.end() );
  Overlay_traits ot;
  BOOST_CHECK_NO_THROW( CGAL::overlay( arr1, arr2, ovl, ot ) );
  BOOST_CHECK( ovl.is_valid() );
BOOST_AUTO_TEST_CASE( overlay_test )
  std::stringstream s( "20  3.70241 10.0638  3.54263 10.1538  3.38164 10.2439  3.21941 10.334  3.05592 10.424  2.89125 10.5135  2.72572 10.6018  2.56035 10.6874  2.3986 10.7661  2.25663 10.8221  2.31918 10.6983  3.24394 9.79979  4.12975 8.9881  5.0517 8.20885  6.01939 7.4895  7.04448 6.89657  8.12341 6.63783  9.06354 7.42606  9.38395 6.81832  7.88638 5.3789 25  3.21425 2.04354  3.07152 2.43112  2.93596 2.82442  2.80939 3.22403  2.69432 3.63062  2.5944 4.04491  2.51512 4.46754  2.46531 4.89881  2.45992 5.33766  2.52623 5.77874  2.71533 6.20316  3.10621 6.55775  3.73189 6.77633  4.61629 6.97293  5.36802 7.23286  5.88393 7.64123  4.55026 7.73043  3.71892 6.45533  3.4668 4.97397  3.68516 3.85621  4.78068 3.84595  6.19292 4.88864  7.35157 6.06477  7.76977 6.93931  6.44483 4.26612 49  3.39727 3.30167  3.729 3.77455  4.06235 4.24953  4.3974 4.72669  4.73425 5.20612  5.07301 5.68791  5.41377 6.17215  5.75665 6.6589  6.10176 7.14821  6.44921 7.64006  6.79908 8.13431  7.15135 8.6306  7.50581 9.12808  7.86175 9.62477  8.21707 10.1158  8.5648 10.5871  8.87361 10.9797  8.77222 10.6321  7.95184 9.13501  6.72429 7.55305  5.80865 7.30431  4.94529 8.47939  5.82739 9.62459  7.53309 9.12544  8.32274 7.73079  7.93102 6.17848  7.26714 5.11697  6.90449 4.27841  7.1238 3.44922  8.82289 2.90117  5.31564 1.66053  4.53624 1.5201  3.9417 1.51973  3.57666 1.67813  3.30579 1.92289  3.10673 2.19562  2.95313 2.47342  2.8287 2.75002  2.72428 3.02377  2.63439 3.29433  2.55555 3.56179  2.48542 3.82634  2.42236 4.0882  2.36514 4.34759  2.31286 4.60469  2.26481 4.85969  2.22043 5.11272  2.17926 5.36394  2.14297 5.59981 25  1.32114 2.07289  2.37628 2.44979  3.41099 2.92486  4.40552 3.52262  5.32495 4.27379  6.10651 5.21085  6.63724 6.34333  6.72124 7.54054  6.03814 7.8217  4.65939 6.89521  8.06583 8.72626  7.76416 10.829  6.93744 10.831  6.44036 10.5234  6.04502 10.2111  5.69272 9.89885  5.36613 9.58767  5.05725 9.27782  4.76159 8.9694  4.47633 8.6624  4.19953 8.35678  3.92981 8.05248  3.66616 7.74945  3.40777 7.44765  3.31723 7.34084 9  1.05133 3.49144  0.977792 4.93342  1.15934 6.40579  1.7234 7.86004  2.81679 9.17858  4.4883 10.1899  6.54077 10.8003  7.71263 11.1415  6.54919 10.5242" );
  boost::array<Curve, 5> curves;
  for ( unsigned i = 0; i < 5; ++i )
    s >> curves[i];
  CGAL::insert_curves( arr1, curves.begin(), curves.begin() + 3 );
  CGAL::insert_curves( arr2, curves.begin() + 2 , curves.end() );
  Overlay_traits ot;
