- To:
- Subject: Non-uniform surface meshing
- Date: Thu, 17 Apr 2008 17:11:42 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:mime-version:content-type:content-transfer-encoding:content-disposition:x-google-sender-auth; b=lMgRweUJvoZ9H8Na66IT0CqW+SL38T2pmNbwYMDiIz1KTB6TfolVTXPFjo9Jot7WXfsTYBcHR5BPtVCpUpZ+ylIhxVcn/VZtVDAkoejp6K5eAOYMMwGbZmOnws9wTzjQnq2J6/6eIFlqQ2si/wW2H93W6fXxQ9YT5D832B63gMo=
Hi,
I would like to construct a non-uniform surface mesh using the Surface
Mesh Generator interface (something like "Experiment 2" in the IPMI
2007 paper by Pons et al. "High-quality consistent meshing of
multi-label datasets").
As far as I understand, this functionality is not available in CGAL right now.
Could anyone help me and point me at a place in the code, where I
could do the changes necessary to specify and check variable size
constraint? Is this something doable?
Thank you
Andrey Fedorov
- Non-uniform surface meshing, Andriy Fedorov, 04/17/2008
- Re: [cgal-discuss] Non-uniform surface meshing, Laurent Rineau, 04/18/2008
- Re: [cgal-discuss] Non-uniform surface meshing, Andriy Fedorov, 04/18/2008
- RE: [cgal-discuss] Non-uniform surface meshing, Santosh Tiwari, 04/18/2008
