cgal-discuss - Re: [cgal-discuss] Non-uniform surface meshing
  • To:
  • Subject: Re: [cgal-discuss] Non-uniform surface meshing
  • Date: Fri, 18 Apr 2008 09:36:33 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=LyGZZaT1rO1LCcQsD4qrGzDXjr2YOO9qkmaO1Tq5t3FnzU6keGIFXPfFIg8hpZMwVVLzt2w+Dtrvos6/bK8aWP4/Z106CoiPUpyXZ8Set/wrgbh8Z5cIbT8lmri7pMx13UKA1qWZSA7hIZkGZyGMlNSU5qnw/8iBw4WyxXnk9xs=
Laurent,
Thank you for the reply. This is very helpful. I will try to do what
you suggest, and maybe ask more questions if I have problems.
I promise, I will absolutely definitely acknowledge CGAL appropriately!
Andrey
On Fri, Apr 18, 2008 at 4:39 AM, Laurent Rineau
wrote:
> On Thursday 17 April 2008 23:11:42 Andriy Fedorov wrote:
> > Hi,
> > I would like to construct a non-uniform surface mesh using the Surface
> > Mesh Generator interface (something like "Experiment 2" in the IPMI
> > 2007 paper by Pons et al. "High-quality consistent meshing of
> > multi-label datasets").
> Hi, I am the author of the Surface Mesh Generator package in CGAL. As a
> matter
> of fact, I am co-author of the paper you talk about.
> > As far as I understand, this functionality is not available in CGAL right
> > now.
> > Could anyone help me and point me at a place in the code, where I
> > could do the changes necessary to specify and check variable size
> > constraint? Is this something doable?
> The Surface Mesh Generator uses a concept for classes that specify the
> meshing
> criteria:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher_ref/Concept_SurfaceMeshCriteria_3.html
> The easiest way to tweak you own sizing function is to modify the class
> CGAL::Surface_mesh_default_criteria_3<Tr>. You can tweak the code of the
> class
> CGAL::Surface_mesher::Uniform_size_criterion<Tr> in the header
> <CGAL/Surface_mesher/Standard_criteria.h>.
> If you manage to publish an article using that software, and I hope you
> will,
> do you forget to cite CGAL. See that page for suggestions about how to cite
> CGAL:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/acknowledge.html
> Laurent Rineau
> INRIA - Sophia Antipolis
> BP 93, 2004 Route des Lucioles
> 06902 Sophia Antipolis Cedex FRANCE
> Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
