cgal-discuss - [Polyhedron, Mesh ] Need a help to access vertex, halfedge, and faces after building polygons
  • To: <>
  • Subject: [Polyhedron, Mesh ] Need a help to access vertex, halfedge, and faces after building polygons
  • Date: Tue, 22 Apr 2008 17:15:04 +0200
  • Organization: Purdue
Hello,
I am struggling in building 3D meshes from a set of points of 3D model (object file). I modified the example source code “Polyhedron_prog_incr_builder.cpp” as follows. After making all triangles from a set of points, I want to travel the meshes with the index and want to get vertex position. And I also need to find neighbor triangles sharing halfedges. How should I do this? I need your help. . I would really appreciate that you can send me a good example. Thank you in advance
Samuel
template <class HDS>
class Build_triangle : public CGAL::Modifier_base<HDS> {
public:
    Build_triangle() {}
    void operator()( HDS& hds) {
        // Postcondition: `hds' is a valid polyhedral surface.
        CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
                int numofvertices = 1000; // Just define the number of surface points of 3D model
                int numoffaces = 70;
       B.begin_surface(numofvertex, numoffaces, 2* numofvertices);
       typedef typename HDS::Vertex   Vertex;
       for(int i=0;i< numofvertices; i=+3 )
                  B.add_vertex( Points[i]));
B.add_vertex( Points[i+1]));
B.add_vertex( Points[i+2]));
  B.begin_facet();
   B.add_vertex_to_facet( i);
   B.add_vertex_to_facet( i+1);
   B.add_vertex_to_facet( i+2);
   B.end_facet();
       B.end_surface();
typedef CGAL::Simple_cartesian<double>     Kernel;
typedef CGAL::Polyhedron_3<Kernel>         Polyhedron;
typedef Polyhedron::HalfedgeDS             HalfedgeDS;
int main() {
    Polyhedron P;
    Build_triangle<HalfedgeDS> triangle;
    P.delegate( triangle);
    CGAL_assertion( P.is_triangle( P.halfedges_begin()));
 /// I want to access vertex, half edges , and faces here ////
    return 0;
