- To:
- Subject: Re: [cgal-discuss] OpenCV and CGAL
- Date: Thu, 24 Apr 2008 13:48:57 +0200
wrote:
Thank you very much!
Do you know also which macro is responsible for the trouble with highgui.h?
The error message might tell you.
Note that the solution to #undef will not work for everything.
Namely when in your code you explicitely or implicitely the
feature that pollutes the namespace.
andreas
- Re: Re: [cgal-discuss] OpenCV and CGAL, novacheva, 04/24/2008
- Re: [cgal-discuss] OpenCV and CGAL, Andreas Fabri, 04/24/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] OpenCV and CGAL, Wesley Smith, 04/24/2008
- Re: [cgal-discuss] OpenCV and CGAL, Sylvain Pion, 04/24/2008
