- To:
- Subject: Re: [cgal-discuss] OpenCV and CGAL
- Date: Thu, 24 Apr 2008 19:32:09 +0200
Wesley Smith wrote:
I actually had exactly the same problem yesterday with min and max
defines. This was with VS2008. I had to do the following:
#ifdef min
#define MIN_MACRO min
#define MAX_MACRO max
#undef min
#undef max
#else
#define MIN_MACRO
#define MAX_MACRO
#endif
my code
#define min MIN_MACRO
#define max MAX_MACRO
I was kind of surprised that there were macros with names min and max
in CGAL since these are such common names, they're bound to conflict.
Wesley,
But where did you find them? As I wrote, we all replaced them,
so if we missed one it's a bug and you could help us to fix it.
andreas
wes
On Thu, Apr 24, 2008 at 10:23 AM, Andreas Fabri
wrote:
Angelina,
wrote:
Andreas was right (as usual) Thanks! - it was not as hopeless as I thoughtto look through the huge error list :)
Here what does the job(in case someone else needs it too):
#undef min
#undef max
That's strange. We made quite an effort to live with the
#define of min and max as they are also defined in the
Microsoft header file windows.h.
Undefining them is in general a bad idea, as Microsoft products
simply need these defines.
In case the appearances of min(a,b) are in your own code, the
workaround is to wrap the word "min" as follows
(min)(a,b)
The additional parethesis prevents the preprocessor to do its work.
andreas (who is not always right)
- Re: Re: [cgal-discuss] OpenCV and CGAL, novacheva, 04/24/2008
- Re: [cgal-discuss] OpenCV and CGAL, Andreas Fabri, 04/24/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] OpenCV and CGAL, Wesley Smith, 04/24/2008
- Re: [cgal-discuss] OpenCV and CGAL, Sylvain Pion, 04/24/2008
