cgal-discuss - Re: [cgal-discuss] insert voronoi edges into arrangement
  • To:
  • Subject: Re: [cgal-discuss] insert voronoi edges into arrangement
  • Date: Tue, 29 Apr 2008 11:13:50 +0300
Quoting
Hi List,
I'm new to CGAL and I'd like to do the following:
Insert the voronoi edges into an arrangement. Like this:
typedef CGAL::Voronoi_diagram_2<SDG2,SDG2_AT2,SDG2_AP2> VD;
typedef CGAL::Arr_conic_traits_2<Rat_kernel,
Alg_kernel,
Nt_traits> Traits_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
VD vd;
Arrangement_2 arr;
Edge_iterator eit = vd.edges_begin();
for ( ; eit != vd.edges_end(); ++eit) {
insert_curve(arr, *eit);
*eit is no curve, so I get an error, but how can I do it otherwise ?
You got it. You have to insert the curve. Extract the curve from the Voronoi edge iterator, and insert it.
Can someone help me?
Thank you very much in advance,
Paul
