- To:
- Subject: Re: [cgal-discuss] insert voronoi edges into arrangement
- Date: Tue, 29 Apr 2008 10:49:23 +0200
Thank you for the reply,
I tried this:
Traits_2::Curve_2 Curve_2;
insert_curve(arr, Curve_2(*eit));
but still get an error. So what exactly do you mean with "extract".
Thank you,
Paul
schrieb:
Quoting
Hi List,
I'm new to CGAL and I'd like to do the following:
Insert the voronoi edges into an arrangement. Like this:
typedef CGAL::Voronoi_diagram_2<SDG2,SDG2_AT2,SDG2_AP2> VD;
typedef CGAL::Arr_conic_traits_2<Rat_kernel,
Alg_kernel,
Nt_traits> Traits_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
VD vd;
Arrangement_2 arr;
Edge_iterator eit = vd.edges_begin();
for ( ; eit != vd.edges_end(); ++eit) {
insert_curve(arr, *eit);
*eit is no curve, so I get an error, but how can I do it otherwise ?
You got it. You have to insert the curve. Extract the curve from the Voronoi edge iterator, and insert it.
Can someone help me?
Thank you very much in advance,
Paul
- insert voronoi edges into arrangement, neugebap, 04/28/2008
- Re: [cgal-discuss] insert voronoi edges into arrangement, efif, 04/29/2008
- Re: [cgal-discuss] insert voronoi edges into arrangement, Paul Neugebauer, 04/29/2008
- Re: [cgal-discuss] insert voronoi edges into arrangement, Efi Fogel, 04/29/2008
- Re: [cgal-discuss] insert voronoi edges into arrangement, Ophir Setter, 04/29/2008
