- To:
- Subject: Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge
- Date: Tue, 29 Apr 2008 12:06:36 +0300
Quoting
The documentation of Arrangement Halfedges, here:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2_ref/Concept_ArrangementDcelHalfedge.html
States the the function e->vertex() produces the target vertex. Don't DCEL structure usually produce the incident (source) vertex?
No. You can get one from the other, as you probably know.
is it an error of documentation?
No
Amir
- "Target Vertex" in ArrangementDcelHalfedge, avaxman, 04/29/2008
- Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, efif, 04/29/2008
- RE: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Amir Vaxman, 04/29/2008
- RE: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Amir Vaxman, 04/30/2008
- Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Efraim Fogel, 04/30/2008
