- To: <>
- Subject: RE: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge
- Date: Tue, 29 Apr 2008 12:06:18 +0300
I guess I could use opposite()->target(), and get the source, but it seems
unconventional, since usually edges point to their source (as vertices point
to an incident "going-out" edge..)
-----Original Message-----
[mailto:]
Sent: Tuesday, April 29, 2008 12:07 PM
To:
Subject: Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge
Quoting
> The documentation of Arrangement Halfedges, here:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2_ref/Concept_ArrangementDcelHalfedge.html
> States the the function e->vertex() produces the target vertex.
> Don't DCEL structure usually produce the incident (source) vertex?
No. You can get one from the other, as you probably know.
> is it an error of documentation?
No
> Amir
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- "Target Vertex" in ArrangementDcelHalfedge, avaxman, 04/29/2008
- Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, efif, 04/29/2008
- RE: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Amir Vaxman, 04/29/2008
- RE: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Amir Vaxman, 04/30/2008
- Re: [cgal-discuss] "Target Vertex" in ArrangementDcelHalfedge, Efraim Fogel, 04/30/2008
