- To:
- Subject: Re:Re: [cgal-discuss] add customized information in delaunay terrain
- Date: Tue, 29 Apr 2008 23:21:46 +0800 (CST)
Hi,
thank you for the help with my problem.
the example of using cumtomized vertices in the manual is about two/three dimension delaunay triangulation,but what i want to obtain is a delaunay terrain,so i should include<CGAL/Triangulation_euclidean_traits_xy_3.h>,and pass a Geomtrait Gt as parameter to "typedef CGAL::Delaunay_triangulation_2<Gt>".
maybe there are some differences between delaunay triangulation and delaunay terrain when adding customized information into vertex.
在2008-04-29,"Daniel Duque Campayo" <> 写道:
独栋情境别墅230万起,品鉴热线:60692999
- Re:Re: [cgal-discuss] add customized information in delaunay terrain, sanlington, 04/29/2008
- [cgal-discuss] Find the smallest triangle on Polyhedron data structure, samuel kim, 04/29/2008
