cgal-discuss - RE: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a polygon mesh?
  • To: <>
  • Subject: RE: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a polygon mesh?
  • Date: Mon, 5 May 2008 15:50:04 +0800
  • Importance: Normal
PS:
Before you can compile and run demos you should install CGAL library correctly, maybe be you also need the boost. You can download it from boost.org, the latest version is 13.5.
Please speak English in this group, maybe somebody who do not know foreign language will be antipathetic.
你好,在运行CGAL库提供的那些DEMO前你可能要正确的安装它与配置好,你可能还要依赖boost库,你可以下载并编译它。
群里请尽量说Enligsh或者干脆双语,否则人家可能会觉得反感。
> Date: Mon, 5 May 2008 09:41:35 +0200
> From:
> To:
> Subject: I am new to CGAL -- was Re: [cgal-discuss] Reverse the winding of a polygon mesh?
> 姜娜 wrote:
> > Hi,all
> > I am new to CGAL,I want to know how to import a polygon_3 mesh data and what
> > packages should be included.
> Hi Linda,
> as you are new:
> - Never reply to a mail starting with a completely new topic.
> - Have a look at the online manual and maybe start with the package overview:
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/packages.html
> Click on "Polygons and Polyhedra"
> In the paragraph on "3D Polyhedral Surface" you see on the right links to
> the User and Reference Manual. The former is full of examples which should
> answer your question.
> Best regards,
> andreas
> > can someone help me ?
> > linda
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Explore the seven wonders of the world Learn more!
