RE: [cgal-discuss] [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge
- To: <>
- Subject: RE: [cgal-discuss] [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge
- Date: Thu, 8 May 2008 20:46:32 +0200
- Organization: Purdue
Title: [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge
Dear all, I am sorry to interrupt you a
lot because of this problem. However, I would appreciate that you can
understand my situation. For your better
understanding, I attached two text files which were output on my program. On
the text files, A, B and C are 3D points of vertices of each triangle traveled.
You will see they change gradually in both files, which means going on a different
way. Travelpoints_firsttraveling.txt shows a list of triangles traveled at
first time, travelpoints_retraveling.txt is the output re-traveled according to
the routine saved into a file as the first traveling triangles. So if I use Halfedge_handle,
is there no guarantee to get the same value when move the edge handle? Is there
any way I can load the same starting facet of triangles whenever reload 3D
model (.off)? If the order of facets of 3D model is kept as the same whenever reload the
model, I should not see this problem. That is, from the below one line
source code, I should be able to get the same facet handle (the same triangle
with same location on 3D model), every time reads 3D object file(.off) using
CGAL lib. I thought so because the object file(.off) has the same order of
vertex points which does not change. How could the facet handle be randomly
changed whenever read the same object file? If so, is there any way in using CGAL
to keep the facet handle and edge handle unchanged on reading 3D model file? Any
idea is welcomed. Halfedge_handle pHalfedge = pFacet->facet_begin();
Thank you. Samuel From: samuel kim
[mailto:] Hi all, I have been trying to traveling triangles of 3D model for my research. But the problem is that the half edge handle
return different values whenever reload 3D model. What I am doing
now, 1)
In encoder, open any 3D model(.off) using CGAL,
as traveling triangles of mesh by using halfedge, determine whether go to the right
direction or left direction on each triangle and save the route into a file, namely the file contains the traveling information on
triangles of the mesh. And
shows traveled triangles. 2)
In decoder, open the same 3D
model(.off), and start
traveling according to the
saved route from the file. And
shows the traveled triangles. In
comparison of the above two, the result shows different route on the 3D model. But
the first starting
triangle is exactly same.
Can you help me to make the
same traveling on the same 3D
model? If you have a idea please share with me, I have spent almost a week on
this. I am using the
below pseudo source code. Halfedge_handle pHalfedge =
pFacet->facet_begin(); Halfedge_handle
pRight_Halfedge = pHalfedge->next()->opposite(); Halfedge_handle
pLeft_Halfedge = pHalfedge->prev()->opposite(); do{ //Some source code here // for traveling to the
right triangle from the
current triangle
If(right == true) pHalfedge =
pRight_Halfedge; else pHalfedge = pLeft_Halfedge; }while(exit !=true) Thank you in advance. Samuel |
A:0.004328 0.131471 0.032140
B:0.016010 0.129844 -0.005956
C:-0.028753 0.125828 0.021231
key:1
index: 1
A:-0.028753 0.125828 0.021231
C:-0.023526 0.114897 -0.017655
key:1
index: 2
A:-0.023526 0.114897 -0.017655
C:0.036731 0.095801 -0.018164
key:1
index: 3
A:0.036731 0.095801 -0.018164
C:0.051056 0.084185 0.010698
key:1
index: 4
A:0.051056 0.084185 0.010698
C:0.037065 0.111856 0.031790
key:0
index: 5
B:0.037065 0.111856 0.031790
C:0.017975 0.068191 0.054168
key:0
index: 6
B:0.017975 0.068191 0.054168
C:0.057299 0.050971 0.019181
key:1
index: 7
A:0.057299 0.050971 0.019181
C:-0.004208 0.035067 0.050396
key:0
index: 8
B:-0.004208 0.035067 0.050396
C:0.023506 0.036240 0.028841
key:1
index: 9
A:0.023506 0.036240 0.028841
C:-0.027824 0.036715 0.040889
key:1
index: 10
A:-0.027824 0.036715 0.040889
C:-0.047202 0.048497 0.038862
key:1
index: 0
C:-0.028731 0.125825 0.021158
key:1
index: 1
A:-0.028731 0.125825 0.021158
key:1
index: 2
key:1
index: 3
key:1
index: 4
C:0.037540 0.111236 0.032016
key:0
index: 5
B:0.037540 0.111236 0.032016
C:0.018294 0.067552 0.053664
key:0
index: 6
B:0.018294 0.067552 0.053664
C:0.056837 0.050736 0.019787
key:1
index: 7
A:0.056837 0.050736 0.019787
C:-0.004358 0.035132 0.050528
key:0
index: 8
B:-0.004358 0.035132 0.050528
C:0.023894 0.036338 0.028646
key:1
index: 9
A:0.023894 0.036338 0.028646
C:-0.027279 0.036738 0.040466
key:1
index: 10
A:-0.027279 0.036738 0.040466
C:0.025174 0.043427 0.070632
key:1
index: 11
A:0.025174 0.043427 0.070632
C:-0.030917 0.061639 0.041861
key:-842150451
- [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge, samuel kim, 05/08/2008
- RE: [cgal-discuss] [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge, samuel kim, 05/08/2008
