cgal-discuss - Re: [cgal-discuss] [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge
  • To:
  • Subject: Re: [cgal-discuss] [CGAL-discuss] I cannot verify the traveling route saved on 3D model using Halfedge
  • Date: Fri, 9 May 2008 09:12:48 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=vwBdwgr57JERDUcVZfVKOvls2alEkfMz/C0P1RDZnxQ2u0qKhLGX8ySVJiYloBWumTzFjvA8RwLZsb0OT66F54BFEkYSunZb3AFtYhnNY1gpjE6YG2AX0Qcfv4Cg+znw/UQCn6Wcptw++QHvEDZlrx8m57zHNSzcf3IJ1Zt6xbo=
Dear Samuel:
I checked your attached data files.
I dont think you got a correct retraveling as you expected to. As a
matter of fact, if the two 3d mesh you traversed are exactly the same
one as you said, the mesh is not a manifold at all!
Look at the following indices:
In "travelpoints_firstraveling.txt", there are two records:
index: 3
A:0.036731 0.095801 -0.018164 --- v1
B:0.016010 0.129844 -0.005956 --- v2
C:0.051056 0.084185 0.010698 --- v3
key:1
index: 4
A:0.051056 0.084185 0.010698 --- v3
C:0.037065 0.111856 0.031790 --- v4
key:0
And there is the following record in "travelpoints_retraveling.txt"
index: 4
C:0.037540 0.111236 0.032016 --- v5 (different to v1 or v4 !)
key:0
Now you may find what happened. Edge (v2 -- v3) has THREE opposite
vertices (v1, v4 and v5), which means there are 3 facets incident to
the edge!
So I guess v4 and v5 are probably the same vertex! Is there any
mistake when loading their coordinates? Note that their coordinates
are relatively close to each other....
Kevin
