- To:
- Subject: Re: [cgal-discuss] 2D polygon offsetting and Circular Arc Subdivision
- Date: Sat, 10 May 2008 12:41:40 +0100
Marko Kukovec wrote:
Hello!
About a week ago I put a question on this mailing list about
offsetting/insetting 2D polygons in CGAL. I have a problem as I have a
polygons with arcs and lines so I can't directly feed the
offsetting/insetting algorithm. I got an answer from Fernando Cacciola
and he suggested I should polygonize all arcs prior to feeding the
offsetting algorithm. He even pointed out this algorithm
http://www.worldserver.com/turk/computergraphics/CircularArcSubdivision.pdf .
If you have an arc not more than 90 degrees, of radius r,
centred on the origin with start point s and end point e
then the point m = (s+e)/2 is mid way between s and e
and its distance from the arc is r-length(m).
So it should be possible to adapt this...
OutIter varc(Vector const s,Vector const e,double const r,
double const delta,OutIter res)
Vector m = (s+e)/2;
double const l = length(m);
if (r-l > delta)
m *= r/l;
res = varc(s,m,r,delta,res);
*res = m;
++res;
res = varc(m,e,r,delta,res);
return res;
...to vector a general arc.
HTH, Louis.
- 2D polygon offsetting and Circular Arc Subdivision, Marko Kukovec, 05/09/2008
- Re: [cgal-discuss] 2D polygon offsetting and Circular Arc Subdivision, Louis Lavery, 05/10/2008
