- To:
- Subject: non-convex Objects from Pointset
- Date: Sat, 10 May 2008 23:29:32 +0200
Hi there everybody,
I've started working with CGAL some days ago and I'm a little overwhelmed
with all the possibilities and the complexity of this library. Right now I'm
at a point where I'm not sure if I find a solution for "my problem" on my
own. That's why I'm writing here now.
I'm starting with a arbitrary set of 3D-points representing the surface of an
object with random orientation in space - and I'm trying to create a set of
faces approximating this surface - e.g. for displaying in OpenGL.
Right now I use a CGAL::Triangulation_3 to create a set of cells. From these
cells I extract the finite facets of the infinite cells to get the
boundary-faces. So now I've got a closed convex object describing the given
surface (as long as it has no bumps or the like) and capping the space
surrounded by this object.
Now I've got 2 problems I could not yet handle with this approach:
1 - what if my surface is not really smooth but has bumps - how can I keep
them?
2 - how can I remove the "capping" faces?
Of course the best solution would be if I could just create a set of faces
describing my surface directly - but I could not find a way to do this.
So can anybody help me here?
Either by giving me pointers how to handle the 2 problems I have with my
current approach or by showing me a way to create a surface right away?
(One way would probably be to project the points onto a plane and do a
2D-triangulation but this is how I did it before CGAL and exaclty that is
what I want to avoid by introducing 3D-computation)
Any help would be absolutely appreciated.
With best regards,
Sven
- non-convex Objects from Pointset, andres, 05/10/2008
