- To:
- Subject: Voronoi Edge problem
- Date: Wed, 14 May 2008 12:04:13 +0200
Hi all,
I have a problem with Voronoi Diagram.
I want to transfer a Voronoi Diagram edge(which is a Halfedge) to Curve_2;
I do it like this.
for (Edge_iterator edit = vd.edges_begin(); edit != vd.edges_end(); ++edit) {
Halfedge hedg = *edit;
Curve_2 curve( ) // here i want to transfer the halfedges to curves
all the information i can get from the Halfegde is the source and the target:
hedg.target()->point();
But this is of course not enough to describe the hole Curve_2.
Can someone help me?
Thank you very much in advance,
Fix
- Voronoi Edge problem, fixpaul, 05/14/2008
