cgal-discuss - Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • To:
  • Subject: Exact_predicates_exact_constructions_kernel_with_sqrt and Nef_polyhedron_3
  • Date: Wed, 14 May 2008 11:51:24 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=wGB7GdQhROyhC1thD0IpD+rAnrgsfJ3i0KLoPUL8dmF/CnKGxe5vpr7msEOSvr8oHXB7ZYO3ZmOba9qNLXcAaDkUjmsBHl3eFT9hqNqwJcSrYVhAfUxRPtqt+YmLIxYkysqBvK/fzgg67OgOAZ6Oc2SeJRq3dfueWuz5zELF/EU=
Hi, all
I run into some issue when using Nef_polyhedron_3 with Exact_predicates_exact_constructions_kernel_with_sqrt Kernel.
To be specific, here is the simple program I was testing:
#include <CGAL/Exact_predicates_exact_constructions_kernel_with_sqrt.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt Kernel;
typedef Kernel::Point_3                               Point_3;
typedef CGAL::Polyhedron_3<Kernel>         Polyhedron;
typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<Kernel, Items>  Nef_polyhedron;
int main() {
    Point_3 p( 1.0, 0.0, 0.0);
    Point_3 q( 0.0, 1.0, 0.0);
    Point_3 r( 0.0, 0.0, 1.0);
    Point_3 s( 0.0, 0.0, 0.0);
    Polyhedron P;
    P.make_tetrahedron( p, q, r, s);
    Nef_polyhedron N2(P);
    return 0;
I am using Visual Studio 2003 and Visual Studio 2005 with CGAL 3.3.1. When runing in Release mode, everything runs fine. But when running in Debug mode, I got the following errors:
Is this a bug in CGAL or did I do something wrong? I can not figure this out, can anybody help me out?
Joe
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(300): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(305): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(310): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(315): error C2064: term does not evaluate to a function taking 3 arguments
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(323): error C2440: 'type cast' : cannot convert from 'std::allocator<_Ty>::value_type' to 'CGAL::Cartesian_base_no_ref_count<FT_,Kernel_>::FT'
        with
            _Ty=CGAL::Fraction_traits<FT>::Numerator_type
        and
            FT_=CORE::Expr,
            Kernel_=CGAL::Simple_cartesian<CORE::Expr>
        No constructor could take the source type, or constructor overload resolution was ambiguous
        with
        and
            FT_=CORE::Expr,
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(324): error C2440: 'type cast' : cannot convert from 'std::allocator<_Ty>::value_type' to 'CGAL::Cartesian_base_no_ref_count<FT_,Kernel_>::FT'
        with
        and
            FT_=CORE::Expr,
        with
        and
            FT_=CORE::Expr,
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(306): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(307): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(308): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(309): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(311): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(312): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(313): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(314): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(316): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(317): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(318): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h(319): error C2676: binary '*=' : 'std::allocator<_Ty>::value_type' does not define this operator or a conversion to a type acceptable to the predefined operator
        with
C:\Program Files\CGAL-3.3.1\include\CGAL\float.h(133): warning C4244: 'return' : conversion from 'double' to 'CGAL::Algebraic_structure_traits_base<Type,Algebra_type>::Type', possible loss of data
        with
            Type=float,
            Algebra_type=CGAL::Field_with_kth_root_tag
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(85): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(90): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\CGAL-3.3.1\include\CGAL\Handle.h(91): warning C4311: 'reinterpret_cast' : pointer truncation from 'CGAL::Rep *const ' to 'unsigned long'
C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\xtree(484): warning C4800: 'int' : forcing value to bool 'true' or 'false' (performance warning)
