- To:
- Subject: Question about Estimation of Local Differential Properties
- Date: Wed, 28 May 2008 05:42:47 +0100
Hello -
I'm looking to use the jet-fitting algorithm to compute the principal curvature and directions at various non-vertex points of a (triangular mesh) i.e. my points of interest lie on the faces of a mesh, and by definition, do not coincide with its vertexes.
My question however concerns the method used by the implementation of the jet-fitting algorithm in this case. I would like to confirm if the jet-fitting algorithm uses an (a) interpolation or (b) approximation approach to compute the differential properties at such no-vertex points -- the former would be preferred.
I'm aware that this issue was discussed on page 12 of "Jet fitting 3: A Generic C++ Package for Estimating the Differential Properties on Sampled Surfaces via Polynomial Fitting", but I found the reading a bit confusing probably because I'm only just learning the algorithm.
Thanks,
- Olumide
- Question about Estimation of Local Differential Properties, Olumide, 05/28/2008
- Re: [cgal-discuss] Question about Estimation of Local Differential Properties, Marc Pouget, 05/29/2008
- [cgal-discuss] Is there an existing function to get the bbox of a polyhedron_3, Max, 05/30/2008
- Re: [cgal-discuss] Is there an existing function to get the bbox of a polyhedron_3, Andreas Fabri, 05/30/2008
