Re: Re: [cgal-discuss] Is there an existing function to get the bboxof a polyhedron_3
- To: "" <>
- Subject: Re: Re: [cgal-discuss] Is there an existing function to get the bboxof a polyhedron_3
- Date: Sat, 31 May 2008 20:24:10 +0800
- Organization: Max
>Hi Max,
>There is no bbox() member function that caches and updates
>the bbox whenever you change the Polyhedron_3.
>The most compact piece of code for computing the bbox in linear time
>looks like this
>#include <CGAL/bounding_box.h>
>Polyhedron_3 poly;
>CGAL Bbox_3 bb = CGAL::bounding_box(poly.points_begin(),
>points_end()).bbox();
>andreas
Hello andreas,
Thank you very much for your quick and detailed reply.
That's enough for my current demand.
B/Rgds
Max
- Question about Estimation of Local Differential Properties, Olumide, 05/28/2008
- Re: [cgal-discuss] Question about Estimation of Local Differential Properties, Marc Pouget, 05/29/2008
- [cgal-discuss] Is there an existing function to get the bbox of a polyhedron_3, Max, 05/30/2008
- Re: [cgal-discuss] Is there an existing function to get the bbox of a polyhedron_3, Andreas Fabri, 05/30/2008
- Re: Re: [cgal-discuss] Is there an existing function to get the bboxof a polyhedron_3, Max, 05/31/2008
