Re: [cgal-discuss] [CGAL-DISCUSS] A compile error when define Halfedge_handle in the structure
- To:
- Subject: Re: [cgal-discuss] [CGAL-DISCUSS] A compile error when define Halfedge_handle in the structure
- Date: Thu, 5 Jun 2008 15:16:55 +0200
On Jun 4, 2008, at 9:46 PM, samuel kim wrote:
Hi all,The structure being defined "out of class" you must tell the compiler what a Halfedge_handle is, and do so
I am programming on enriched_polyhedron.h and want to use a global structure defined as follows, but it produces an error when compiling because compiler does not recognize the Halfedge_handle. The below structure was declared out of classes in the header file of “enriched_polyhedron.h” to be used as a global.
struct FEATURE_III_DATA{
int curverindex; // current vertex index
int facetindex; // the index of facet having the normals
double binradius; // bin angle radius
Halfedge_handle pHalfedgehandle;
in your structure (if I understand your problem correctly):
typedef Enriched_polyhedron<WithYourTemplateParameters>::Halfedge_handle Halfedge_handle;
sam
- [CGAL-DISCUSS] A compile error when define Halfedge_handle in the structure, samuel kim, 06/04/2008
- Re: [cgal-discuss] [CGAL-DISCUSS] A compile error when define Halfedge_handle in the structure, Samuel Hornus, 06/05/2008
