- To:
- Subject: [cgal-discuss] offsetting a polygon
- Date: Tue, 10 Jun 2008 06:24:07 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Received:X-Mailer:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type:Message-ID; b=WF+awYH2LO0Io67c3OWyCJdthUvjKilsiKkd1SYvYVKei73dAKlVlLRDvPNqqMG4WEqJeNfPPHlt+MpgNWftMdT/6Ls+zEMhG9mXxhcS+MS7o4HfI9AWa0DGmsvvTkM7oJWHmZLGZf2NIC206PvFmu68r0ysFY2a9360gywDBYM=;
hi... i am trying to find the minkowski sum of a polygon and a circle under the code provided in Minkowski_sum_2 but the output for provided example is as foolows: Read an input polygon with 64 vertices. The offset polygon has 109 vertices, 0 holes. Offset computation took 0.087987 seconds. It does not providing the vertices co-ordinates and how those vertices are connected..............how to get this information........... thanks & regards amit AMIT TRIPATHI 09836562804 M.Tech(C.S.) I.S.I. KOLKATA |
- [cgal-discuss] offsetting a polygon, amit tripathi, 06/10/2008
